Topic: Interrupts (Read 936 times) previous topic - next topic
Claus
Is it possible to use internal interrupts, like Timer0 Int etc.? I could find handling external interrupts in the reference only.
acleone
It is, but you'll have to use straight-up avr-libc (there's no beginner-friendly Arduino methods).  See
http://www.nongnu.org/avr-libc/user-manual/group__avr__interrupts.html
fyi: [font=Courier New]millis()[/font] uses the timer0 overflow - see <arduino folder>/hardware/cores/arduino/wiring.c.  It uses the old style declaration, it should probably be changed to
Code: [Select]
ISR(TIMER0_OVF_vect) {
drone
#2
Dec 02, 2008, 11:04 pm Last Edit: Dec 02, 2008, 11:04 pm by drone Reason: 1
There's also MsTimer2 interface for setting up timer-based interrupts on Timer2 easily.
http://www.arduino.cc/playground/Main/MsTimer2
!c
dcb
with the exception of timer0 overflow, you can define any interrupt you want within arduino.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
