Topic: Wireless sound from one arduino to another (Read 3265 times) previous topic - next topic
tsunamy_boy
Mar 22, 2014, 03:15 am Last Edit: Mar 22, 2014, 06:45 pm by tsunamy_boy Reason: 1
I want to transmit wireless sound from one Arduino to another (microphone and speaker wise)
Specifications:
Distance: A few meters (I was thinking on using RF)
Quality: It doesn't matter
Sound comes from: Microphone (one end)
Sound goes to: Speaker (other end)
Is it possible? Any tips thanks.
fungus
I want to transmit wireless from one Arduino to another (microphone and speaker wise)
What distance?
What quality?
Where does the sound data come from?
How will you convert the data back to sound at the other end?
Why can't you use a $20 wireless microphone?
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
tsunamy_boy
What distance?
A few meters (I was thinking to use RF)
What quality?
It doesn't matter
Microphone
It doesn't matter i just want to transmit and receive sound
Because it's no fun  :P
runaway_pancake
http://en.wikipedia.org/wiki/Photophone
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
tsunamy_boy
I need to pass throw walls and light doesn't do that  =(
runaway_pancake
Any other details?
http://sci-toys.com/scitoys/scitoys/radio/am_transmitter.html
MarkT
Two nRF24L01+'s - can drive these fast with SPI if disable the packet-acknoledgement
system.  Not trivial though.
fungus
My advice is to send it through a wire first so you get the "sound" part working.
Then remove the wire to get the "wireless" part.
tsunamy_boy
ok, but how can i capture the sound?
Is there a schematic for it?
jremington
A microphone and preamplifier comes in handy. Google will provide circuits.
mauried
This is by no means a trivial project.
You will need some kind of audio amplifer which also provides a Dc offset so that the microphone output
falls within the range of the Arduinos A/D converter.
You will also need some kind of simple audio codec to convert the sampled audio into a digital bit stream to feed to the radio.
At the receiving end you will have to do the reverse, and then somehow recover the audio and feed it to an audio amplifier and then a speaker.
Hope you are an experianced Arduino programmer.
tsunamy_boy
Thank you guys, i was thinking on using a sound sensor, will it work to get the sound?
tsunamy_boy
Grumpy_Mike
What sound sensor.
A lot of them are just envelope detectors that will not record the waveform of the sound.
Look here for a circuit of how to get sound into an arduino:-
http://interface.khm.de/index.php/labor/experimente/arduino-realtime-audio-processing/
