Topic: EEMEM directive and EEPROM storage in .HEX files (Read 20949 times) previous topic - next topic
AVRman
Feb 04, 2008, 09:41 pm Last Edit: Feb 04, 2008, 09:42 pm by AVRman Reason: 1
If I declare a eeprom variable like this,
Code: [Select]
EEMEM unsigned char my_storage_byte;
The compiler wants to join EEPROM and FLASH sections into the same .HEX file. This normally would not be a problem, except when AVRdude gets to the end of the .HEX file and doesn't understand that the address he's reading is really an EEPROM address. AVRdude then gives up and crashes.
My guess is that EEPROM and FLASH sections are joined by the Arduino compiler into the same file. Can I tell it not to do this?
How have others dealt with this issue?
mellis
If you set build.verbose to true in your Arduino preferences file, and then run Arduino and compile your sketch, you'll see the command lines passed to avr-g++, etc.  To be honest, I'm not sure how we're handling EEPROM sections, but if you've got specific suggestions for changes to the compilation command lines, let me know.
AVRman
Is it possible to build separate .hex files and .eep files? That way AVRdude would understand.
The makefile would look have something like this in it:
Code: [Select]
## Intel Hex file production flags
HEX_FLASH_FLAGS = -R .eeprom
HEX_EEPROM_FLAGS = -j .eeprom
HEX_EEPROM_FLAGS += --set-section-flags=.eeprom="alloc,load"
HEX_EEPROM_FLAGS += --change-section-lma .eeprom=0 --no-change-warnings
## Build
all: $(TARGET) myHexFileName.hex myHexFileName.eep size
##Link
$(TARGET): $(OBJECTS)
      $(CC) $(LDFLAGS) $(OBJECTS) $(LINKONLYOBJECTS) $(LIBDIRS) $(LIBS) -o $(TARGET)
%.hex: $(TARGET)
     avr-objcopy -O ihex $(HEX_FLASH_FLAGS)  $< $@
%.eep: $(TARGET)
     -avr-objcopy $(HEX_EEPROM_FLAGS) -O ihex $< $@ || exit 0
So before you call to AVRdude, you would just check to see if there was a .eep file. If so, then automatically burn it to EEPROM?
AVRman
Any reason why EEPROM data is being put into the same flash .HEX file if avrdude doesn't understand it?
mellis
Not explicitly.  It's never been an issue, so I've just been doing what's worked.  Here's what I think are the relevant command lines:
hardware/tools/avr/bin/avr-gcc -Os -mmcu=atmega168 -o /tmp/build6214.tmp/ASCIITable.elf /tmp/build6214.tmp/Temporary_9591_5305.cpp.o /tmp/build6214.tmp/core.a -L/tmp/build6214.tmp -lm
hardware/tools/avr/bin/avr-objcopy -O srec -R .eeprom /tmp/build6214.tmp/ASCIITable.elf /tmp/build6214.tmp/ASCIITable.rom
hardware/tools/avr/bin/avr-objcopy -O ihex -R .flash /tmp/build6214.tmp/ASCIITable.elf /tmp/build6214.tmp/ASCIITable.hex
What would they need to be changed to in order to separate the EEPROM and Flash data?
AVRman
I would suggest trying to change this,
Code: [Select]
To this,
Code: [Select]
hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom  /tmp/build6214.tmp/ASCIITable.elf /tmp/build6214.tmp/ASCIITable.hex
hardware/tools/avr/bin/avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" --change-section-lma .eeprom=0 --no-change-warnings -O ihex /tmp/build6214.tmp/ASCIITable.elf /tmp/build6214.tmp/ASCIITable.eep || exit 0
Let me know if that works. If not, we'll look at adjusting the avr-gcc call as well.
On a separate note, wouldn't it be nice to see the AVR memory usage (program/data/eeprom) breakdown right in the compiler output window? This feedback could be useful to some people.
AVRman
To get the memory map,
you use this call,
Code: [Select]
avr-gcc.exe -mmcu=atmega168 -Wl,-Map=/tmp/build6214.tmp/ASCIITable.map /tmp/build6214.tmp/Temporary_9591_5305.cpp.o -o /tmp/build6214.tmp/ASCIITable.elf
mellis
Hmm, definitely something to think about, but probably not a high priority.
Also, I'm not sure if avrdude and our bootloader support writing to the EEPROM.  Have you tried it?
AVRman
Looking through the bootloader code briefly, it looks like AVRdude should be able to burn EEPROM.
But this is not really what I was looking for. I'm just looking to use this:
EEMMEM unsigned char my_var;
And not have it put blank EEPROM variables at the end of the .HEX file (and crash AVRdude)
The reason why you would want this functionality is so you don't have to keep track of where eeprom locations are. You can just create a variable, and the compiler figures out what EEPROM address it should go in. This gets very helpful when dealing with complex structures stored in EEPROM.
ahoeben
#9
Apr 30, 2008, 10:50 pm Last Edit: Apr 30, 2008, 11:01 pm by ahoeben Reason: 1
I'ld love to see support for the EEMEM directive too!
Added to the SuggestionsBugs page on the playground.
ahoeben
#10
May 04, 2008, 03:25 pm Last Edit: May 04, 2008, 03:42 pm by ahoeben Reason: 1
I had a look at the makefile in /hardware/cores/arduino/Makefile, to see if I could get this working. Disclaimer: I don't really know what I am doing.
With two very minor changes to the makefile, it creates an .eep file for me. The .hex file also has the correct filesize, and both the flash and eeprom sections seem to be uploaded. I have not tested the resulting uploads yet (but my arduino is still accepting new uploads, so at least I did not fry the bootloader ;-). Below is a patch:
Code: [Select]
--- /hardware/cores/arduino/Makefile.orig      Fri May 02 18:14:46 2008
+++ /hardware/cores/arduino/Makefile      Sun May 04 15:17:04 2008
@@ -95,6 +95,7 @@
# Programming support using avrdude. Settings and variables.
AVRDUDE_PORT = $(PORT)
AVRDUDE_WRITE_FLASH = -U flash:w:applet/$(TARGET).hex
+AVRDUDE_WRITE_EEPROM = -U eeprom:w:applet/$(TARGET).eep
AVRDUDE_FLAGS = -V -F -C $(INSTALL_DIR)/hardware/tools/avr/etc/avrdude.conf \
-p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER) \
-b $(UPLOAD_RATE)
@@ -127,7 +128,7 @@
# Default target.
all: applet_files build sizeafter
-build: elf hex
+build: elf eep hex
applet_files: $(TARGET).pde
      # Here is the "preprocessing".
@@ -149,8 +150,8 @@
sym: applet/$(TARGET).sym
# Program the device.
-upload: applet/$(TARGET).hex
-      $(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH)
+upload: applet/$(TARGET).hex applet/$(TARGET).eep
+      $(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
      # Display size of file.
@@ -185,7 +186,7 @@
      $(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
.elf.eep:
-      -$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
+      -$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom=alloc,load \
      --change-section-lma .eeprom=0 -O $(FORMAT) $< $@
# Create extended listing file from ELF output file.
edit: edited the patch to also handle uploading the eep section.
mellis
Awesome.
If someone wants to patch the IDE for this as well, that would be great.  Otherwise, I'm afraid it's not too high on the priority list.
ahoeben
#12
May 04, 2008, 06:02 pm Last Edit: May 04, 2008, 06:46 pm by ahoeben Reason: 1
I can have a look if you point me at where the buildproces is in the IDE sources... Like with the makefile, I won't really know what I'll be doing, but I can poke at the code until it works ;-)
The patch above needs some work; it does not like it when there is no .eep file. Is there such a thing as an "elseif" statement in a makefile?
update:
/app/Compiler.java and /app/AvrdudeUploader.java look like the most likely suspects. Time to brush up my java...
ahoeben
Looks like I'll have a patch next week. The changes are very minor, but I need to do some testing with real projects before I can vouch for the code...
ahoeben
#14
May 14, 2008, 10:19 am Last Edit: May 14, 2008, 11:59 am by ahoeben Reason: 1
Hmm, it seems that my initial enthusiasm was somewhat premature... It seems to work fine, until I declare an array in EEMEM, at which point the whole eeprom writing stage fails. I could use an extra pair of eyes...
Code: [Select]
Index: AvrdudeUploader.java
--- AvrdudeUploader.java      (revision 453)
+++ AvrdudeUploader.java      (working copy)
@@ -44,6 +44,7 @@
      Collection params = getProgrammerCommands(Preferences.get("upload.using"));
      params.add("-Uflash:w:" + buildPath + File.separator + className + ".hex:i");
+      params.add("-Ueeprom:w:" + buildPath + File.separator + className + ".eep:i");
      return avrdude(params);
@@ -62,6 +63,7 @@
      "-b" + Preferences.getInteger("boards." + Preferences.get("board") + ".upload.speed"));
    commandDownloader.add("-D"); // don't erase
    commandDownloader.add("-Uflash:w:" + buildPath + File.separator + className + ".hex:i");
+    commandDownloader.add("-Ueeprom:w:" + buildPath + File.separator + className + ".eep:i");
    if (Preferences.get("boards." + Preferences.get("board") + ".upload.disable_flushing") == null ||
        Preferences.getBoolean("boards." + Preferences.get("board") + ".upload.disable_flushing") == false) {
Index: Compiler.java
--- Compiler.java      (revision 453)
+++ Compiler.java      (working copy)
@@ -211,16 +211,20 @@
      List commandObjcopy;
      commandObjcopy = new ArrayList(baseCommandObjcopy);
-      commandObjcopy.add(2, "srec");
+      commandObjcopy.add(2, "ihex");
+      commandObjcopy.set(3, "-j");
      commandObjcopy.add(".eeprom");
+      commandObjcopy.add("--set-section-flags=.eeprom=alloc,load");
+      commandObjcopy.add("--change-section-lma");
+      commandObjcopy.add(".eeprom=0");
      commandObjcopy.add(buildPath + File.separator + sketch.name + ".elf");
-      commandObjcopy.add(buildPath + File.separator + sketch.name + ".rom");
+      commandObjcopy.add(buildPath + File.separator + sketch.name + ".eep");
      if (execAsynchronously(commandObjcopy) != 0)
        return false;
-      commandObjcopy.add(".flash");
+      commandObjcopy.add(".eeprom");
      commandObjcopy.add(buildPath + File.separator + sketch.name + ".hex");
The patch above changes the following:
* Compiler.java is changed so it creates an .eep file in ihex format, instead of a .rom file in srec format
* Compiler.java is changed so the .hex file does not contain the eeprom section
* AvrdudeUploader.java is changed so it also uploads the .eep file to eeprom space
You can use this sketch to test the modifications:
Code: [Select]
#include <avr/eeprom.h>
byte EEMEM NonVolatileChar = 123;
int  EEMEM NonVolatileInt = 12345;
//char EEMEM NonVolatileString[15]; = "Hello world";
   char SRAMchar;
   int SRAMint;
   char SRAMstring[15];
   SRAMchar = eeprom_read_byte(&NonVolatileChar);
   SRAMint  = eeprom_read_word(&NonVolatileInt);
   //eeprom_read_block((void*)&SRAMstring, (const void*)&NonVolatileString, 15);
   Serial.println(SRAMchar,DEC);
   Serial.println(SRAMint,DEC);
   Serial.println(SRAMstring);
When used like this, the code works fine; The NonVolatileChar and NonVolatileInt are read as expected. Uncommenting the EEMEM declaration of NonVolatileString breaks the eeprom upload process for me, and not even the NonVolatileChar and NonVolatileInt read back correctly anymore. This is the same with both the IDE changes in this post and the makefile changes I posted before, though the makefile by default does not verify the written data.
Update: To my untrained eye, it looks like the bootloader is putting bytes in the wrong places in the eeprom section. Something about byte vs word boundaries and/or big vs little endian-ness. The bootloader is special-casing the Atmega 168 when it comes to writing the eeprom section, and I don't understand that code. I'll have to build me an AVR ISP so I can see what exactly gets put in the eeprom, and to see if it works if I use the AVR ISP instead of the bootloader.
