Topic: EEMEM directive and EEPROM storage in .HEX files (Read 19377 times) previous topic - next topic
ahoeben
#15
May 19, 2008, 08:51 pm Last Edit: May 19, 2008, 08:57 pm by ahoeben Reason: 1
Finally had the time to construct my usbtinyisp. Unfortunately, the bootloader seems to foobar the eeprom data during upload. The eeprom data seems to come across intact when I choose to use the usbtinyisp for programming the sketch, but the bootloader munges up a couple of bytes per handful of bytes.
So even *if* I could get this fixed, chances of it getting in are very slim, right? Seeing that it would need a bootloader update...
Either way, it would be great if the following patch could get in; it fixes an actual bug, and solves the original poster's problem.
Code: [Select]
Index: Compiler.java
--- Compiler.java      (revision 453)
+++ Compiler.java      (working copy)
@@ -211,16 +211,20 @@
      List commandObjcopy;
      commandObjcopy = new ArrayList(baseCommandObjcopy);
-      commandObjcopy.add(2, "srec");
+      commandObjcopy.add(2, "ihex");
+      commandObjcopy.set(3, "-j");
      commandObjcopy.add(".eeprom");
+      commandObjcopy.add("--set-section-flags=.eeprom=alloc,load");
+      commandObjcopy.add("--change-section-lma");
+      commandObjcopy.add(".eeprom=0");
      commandObjcopy.add(buildPath + File.separator + sketch.name + ".elf");
-      commandObjcopy.add(buildPath + File.separator + sketch.name + ".rom");
+      commandObjcopy.add(buildPath + File.separator + sketch.name + ".eep");
      if (execAsynchronously(commandObjcopy) != 0)
        return false;
-      commandObjcopy.add(".flash");
+      commandObjcopy.add(".eeprom");
      commandObjcopy.add(buildPath + File.separator + sketch.name + ".hex");
The missing part, requiring a fix to the bootloader, is uploading the .eep file.
ahoeben
Here's a patch for the bootloader. Disclaimer: I don't know exactly why this works, and I don't know if this works with anything but an Atmega168. But with this patch in place, at least the bootloader does not put rubbish into the eeprom of my Atmega168:
Code: [Select]
Index: ATmegaBOOT_168.c
--- ATmegaBOOT_168.c      (revision 453)
+++ ATmegaBOOT_168.c      (working copy)
@@ -482,6 +482,7 @@
          if (getch() == ' ') {
            if (flags.eeprom) {                            //Write to EEPROM one byte at a time
+                address.word = address.word << 1;              //address * 2 -> byte location
                for(w=0;w<length.word;w++) {
#ifdef __AVR_ATmega168__
                  while(EECR & (1<<EEPE));
@@ -627,11 +628,10 @@
          if (address.word>0x7FFF) flags.rampz = 1;            // No go with m256, FIXME
          else flags.rampz = 0;
#endif
+          address.word = address.word << 1;              // address * 2 -> byte location
          if (getch() == 'E') flags.eeprom = 1;
-          else {
-            flags.eeprom = 0;
-            address.word = address.word << 1;              // address * 2 -> byte location
+          else flags.eeprom = 0;
          if (getch() == ' ') {                            // Command terminator
            putch(0x14);
            for (w=0;w < length.word;w++) {                    // Can handle odd and even lengths okay
PS: something else I noticed while hacking my way through the bootloader is that the Atmega168 is special-cased because 'the current avr-libc eeprom functions do not support the ATmega168'. It seems that the current (newer?) version of avr-libc supports eeprom functions for the ATmega168 just fine, though the special-cased m168 workaround  results in a smaller bootloader hex file than using the functions from avr/eeprom.h
mellis
ahoeben: thanks for doing the work on this.  I'll try to incorporate the compilation patches - I'm going to be making some changes to that part of the code anyway.  The bootloader modifications are a lower priority, since we've already burned the bootloader onto a lot of boards.  Next time we change it, though, I'll definitely try to get this in there.
ahoeben
You're welcome, it was (mostly) fun to do. I agree that the compilation changes are the most important for now. With those in place, at least you don't get a wrong .hex file if you use the EEMEM directive. The only functionality missing is setting initial values; reading and writing from within the sketch works fine.
The sooner the bootloader gets fixed, the fewer Arduinos with a (minor) bug will be out there. On the other hand, I fully understand that the bootloader changes would need extensive testing, and the number of people that will encounter the bug is very low (given that the bug has been in the bootloader since ~2005).
ahoeben
Too bad the Pro and the Pro Mini are both shipping with updated bootloaders. but this bug was not fixed. One more generation of shipping Arduinos that can not properly write to the eeprom using the bootloader :-(
ahoeben
Great to see a fix turning up in SVN. Yay!
Ladyada fixed the bootloader side of things for the Atmega328 chips she's currently sending out, so Atmega328-based boards will be among the first that eventually also support uploading to the EEPROM area.
For now, at least we can use the EEMEM directive, without Arduino creating .hex files that are too big.
mellis
If you can figure out a way to get avr-objcopy to create the .eep files without generating a warning if they're empty, that would be even better.  Otherwise, you'll probably need to extract them manually on the command line.
ahoeben
#22
Oct 13, 2008, 08:10 pm Last Edit: Oct 13, 2008, 08:14 pm by ahoeben Reason: 1
Sorry I did not catch that before. This seems to work for me:
Code: [Select]
--- /app/Compiler.java      Mon Oct 13 20:04:37 2008
+++ /app/Compiler.java      Mon Oct 13 20:02:31 2008
@@ -215,6 +215,7 @@
+      commandObjcopy.add("--no-change-warnings");
Edit: This is (obviously) against revision 513, not 514.
mellis
Great, that seems to work.  I'm generating the .eep files again.  Do you think it makes sense to upload the EEPROM data with avrdude on every upload?
ahoeben
Trying to upload anything to the eeprom section on a non-fixed bootloader always results in an upload error (unless you want to turn off verification). So at the very least uploading the .eep section should probably be an option that lives in boards.txt.
Come to think of it, that could be a very good solution, because for example all 328s that Ladyada is shipping currently have the fix in place, so they are eeprom-capable. Atmega328-based Arduinos would have a different entry in boards.txt. And if a user wants to prevent his/her eeprom section from getting overwritten, he/she can edit the boards.txt file to disable the upload. One could even make two copies of a board config; one with and one without eeprom uploads.
mellis
Sounds like a good plan.  I'll add it (at some point).  We will be switching to the updated bootloader as well.
bohne
Can somebody summarize the status of this thread? Is the EEMEM directive now supported and .eep upload working with the bootloader?
http://www.dorkbot.de
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1236434254
http://www.luminet.cc
ahoeben
Since the 0013 release and newer (or was it 0012?),  .eep files are created, but not uploaded. You can upload them manually using avrdude.
bohne
should I create a patch that allows manual upload of .eep files out of the IDE?
Can they be uploaded by the bootloader or only via isp programmer?
Or maybe the IDE must upload the .eep file if the size is not zero or at least ask the user in this case?
Maybe users want to read the eeprom and have a look at the contents in the Editor as well?
Or is the eeprom a topic for professional users only and they all know how to handle avrdude?
ahoeben
Here's a patch that should let you specify in boards.txt whether or not the eep file gets uploaded.
Code: [Select]
Index: AvrdudeUploader.java
--- AvrdudeUploader.java      (revision 540)
+++ AvrdudeUploader.java      (working copy)
@@ -49,6 +49,10 @@
      Collection params = getProgrammerCommands(uploadUsing);
      params.add("-Uflash:w:" + buildPath + File.separator + className + ".hex:i");
+      String eepFile = buildPath + File.separator + className + ".eep";
+      Boolean uploadEEPROM = Preferences.getBoolean("boards." + Preferences.get("board") + ".upload.eeprom_section");
+      if (uploadEEPROM && (new File(eepFile)).exists())
+        params.add("-Ueeprom:w:" + eepFile + ":i");
      return avrdude(params);
@@ -67,6 +71,10 @@
      "-b" + Preferences.getInteger("boards." + Preferences.get("board") + ".upload.speed"));
    commandDownloader.add("-D"); // don't erase
    commandDownloader.add("-Uflash:w:" + buildPath + File.separator + className + ".hex:i");
+      commandDownloader.add("-Ueeprom:w:" + eepFile + ":i");
    if (Preferences.get("boards." + Preferences.get("board") + ".upload.disable_flushing") == null ||
        Preferences.getBoolean("boards." + Preferences.get("board") + ".upload.disable_flushing") == false) {
The reason not to turn this option on for all boards is that there is a bug in most 168-based bootloaders out there that will make the eep uploading process fail. This bug was fixed with the 328-compatible bootloader recently, so all 328-based arduinos should be fine.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
