Topic: MINI PRO. SPIEN fuse problem (Read 1 time) previous topic - next topic
hughrobertson
Hi
I had a MINI PRO connected to Studio 4 via the ISP connection. downloaded some software and tried to run the dubugger. The debugger had problems an changed to  debugWIRE mode. That didnt work either. Upon inspection using the ISP connection (and dragon) the SPIEN fuse had become unset. Is there ant way to reset this fuse.
The chip is a atmega328P
Hugh
madworm
http://mightyohm.com/avr_rescue/
• Upload doesn't work? Do a loop-back test.
• There's absolutely NO excuse for not having an ISP!
• Your AVR needs a brain surgery? Use the online FUSE calculator.
My projects: RGB LED matrix, RGB LED ring, various ATtiny gadgets...
• Microsoft is not the answer. It is the question, and the answer is NO!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
