Topic: ldr pre-process (Read 941 times) previous topic - next topic
Sunjaman
Hi, is there a passive way to compare (<=>) two ldr's voltages and generate a scaled output before arduino input pin? (In case uno's analog pins is not enough)
robtillaart
what is your goal,
what do you want to measure
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Sunjaman
i have 2 photo resistors. each one in a voltage divider circuit. i want to compare these voltages to know which one is bigger or if they are equal. But i want this measurment to be scaled in a way that arduino can handle it. (0 to 5v, or 0, 2.5, 5)
robtillaart
you can use the analog Read for both but you definitely need to calibrate when they are equal.
The ADC of the arduino is multiplexed and often you have noise on your measurements.
So a difference of lets say 3 point on the 0..1023 scale that can be noise.
Rob Tillaart
Sunjaman
i don't want to use arduino for this comparison because there is not enough analog inputs!
larryd
What is the range of resistance of your ldr?
What is the maximum voltage across the ldr?
No technical PMs.
The last thing you did is where you should start looking.
Sunjaman
range 1kOhm to 1.3Mohm, in series with an 10k voltage 5 volts
Sunjaman
larryd
In that configuration, your input to an analog input will be .5 to almost 5 volts.
You don't want to use an Arduino analog i/p and you want to do it using passive components.
I cannot help you here.
No technical PMs.
TomGeorge
Hi, you will have to build some hardware to do the job.
OpAmp will help, but first what do you want out of the comparison.
The arduino analog is only positive  0 to +5V.
A standard differential amplifier will when you compare your two LDR outputs.
If LDR1 is Higher than LDR2 you get a positive voltage out.
If LDR2 is Higher than LDR1 you get a NEGATIVE voltage out.
It can be level shifted so that 2.5V is zero difference, above 2.5V is positive and below 2.5V is negative.
The trick is to do it with a single power supply rather than a balance pos/neg supply.
Tom....... :)
Everything runs on smoke, let the smoke out, it stops running....
