Topic: Don't Format SD cards with OS utilities! (Read 91967 times) previous topic - next topic
brazil
Flinkly
Thanks for this, and SdFat.  I'm still working on buffering (making sense of it, ME here...), but whenever I have a question about Arduino's and SDs, and ask the Google, you (in some flavor) come up and answer my question and more.
If only SDIO didn't seem so much more intimidating than SPI (which is so simple!).
Thanks!
Eimerkette
Thanks for the information about using "SDFormatter V4.0" to format SD card.
Because of having no success to get my "Arduino UNO" - "SD card" running, I searched for posts which describes the same problem. But I didn't found any solution/hint which will help. In the meantime I spend many hours/days...
Therefore I also tried to use "SDFormatter V4.0" to format my SD card, but I did not solve my problem.
My "Arduino UNO" - "SD card" is still not running. That's really frustrating and makes no fun.
The best result (using "CardInfo") was:
Code: [Select]
Initializing SD card...Wiring is correct and a card is present.
Card type: SDHC
Could not find FAT16/FAT32 partition.
Make sure you've formatted the card
but it is hard to reproduce this situation.
Any hints?
_pepe_
#33
Mar 12, 2017, 03:08 pm Last Edit: Aug 19, 2018, 08:15 am by _pepe_
Supprimé
Eimerkette
#34
Mar 12, 2017, 05:15 pm Last Edit: Mar 12, 2017, 06:12 pm by Eimerkette Reason: (Added link to new topic.)
Hi _pepe_,
thanks for this hint.
I'll do it and report the corresponding error codes in a new topic.
dlchambers
Unfortunately, this utility formats the SD as FAT32, but the Arduino SD lib wants FAT16. So the tool is useless.
C1913
Quote
So are cars, if I dont know how to drive them. Or foreign languages I don't speak. They are indeed useless, but to me, not in general.
Only cause you're frustrated is no reason to be rude. People here are there to help you, not to bother you with useless crap   ;)
If google was a country, I'd move there.
fat16lib
Quote
SD cards are designed to be formatted with a layout that matches the card's flash chips.  SDFormatter produces the optimal layout by inserting hidden sectors to adjust the layout to chip boundaries.  SDFormatter chooses an appropriate cluster size.  There are no options for the standard format.
SDFormatter uses FAT12 for very small cards.  FAT16 is used for cards <= 2GB, FAT32 for cards <= 32 GB, and exFAT for cards larger than 32GB.
The SD library supports FAT16/FAT32 and is optimized for the layout SDFormatter produces.
soundlord
#38
Feb 06, 2018, 03:44 pm Last Edit: Feb 07, 2018, 01:46 am by soundlord
I do use the OS utilities to format an SD card but I use a more flexible OS -> Linux. So your advice is correct for Windows users but Linux users should use the internal command as the SD card association doesn't provide a formatting tool for Linux.
So on Linux users may issue the command:
Code: [Select]
mkfs.vfat -F 32 -s 64 -S 512 /dev/sdb1
given that the card is available as /dev/sdb on the system.
This command does the same as the formatter from the SD card association (use 32kB clusters with a FAT32 file system).
Never worked for me... SD.begin(cable select slot) returns 0.
SOLUTION:
In fact you have to (using Linux):
1. have root rights  (su root)
2. in bash (shell) --> msdosfs -I /dev/sdd (assuming /dev/sdd is the sdcard device)
3. in arduino 1.8.5 --> verify you installed the SdFAT library
Use the example called SdFormatter
4. Change the cable select port to 4 for the arduino with LCD module with SD card reader
5. Load the program in the arduino and follow the instructions using the serial monitor
afedorov
I see strange behavior with 32G sd card. Sometimes it initializes some times it doesn't. Can it happen becauseI used MacOs to format the card?
apollinaire
Has anybody yet tried formatting the SD card in a digital camera as a workaround?
I can't test it myself (no SD.shield in my drawer), just an idea...
HarryJack12345
Very Useful Post i have learned more from replies
Thankyou so Much from,
Faiz e Islam.
