Topic: Arduino-0017 Serial Monitor Crash (Read 1 time) previous topic - next topic
Byron
I am running Ubuntu 9.04 on AMD64 quad core.  I finally got the arduino-0017 applet running well enough to upload sketches; however, when I try to monitor serial data replies from my Duemilanove ATmega328P, the serial monitor and the applet crash.  The command line terminal used to launch arduino gives the following error message:
-----BEGIN------------------------------------------------------
./arduino
Experimental:  JNI_OnLoad called.
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version   = RXTX-2.1-7
RXTX Warning:  Removing stale lock file. /var/lock/LCK..ttyUSB0
Binary sketch size: 1766 bytes (of a 30720 byte maximum)
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00007ff9ec0a9333, pid=23696, tid=140711381555536
# JRE version: 6.0_16-b01
# Java VM: Java HotSpot(TM) 64-Bit Server VM (14.2-b01 mixed mode linux-amd64 )
# Problematic frame:
# C  [librxtxSerial-2.1-7.so+0x8333]  read_byte_array+0x43
# An error report file with more information is saved as:
# /home/byron/Electronics/Arduino/arduino-0017/hs_err_pid23696.log
# If you would like to submit a bug report, please visit:
#   http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
./arduino: line 20: 23696 Aborted                 java -Dswing.defaultlaf=com.sun.java.swing.plaf.gtk.GTKLookAndFeel processing.app.Base
-----END------------------------------------------------------------------
Additionally, an error log file is created with the following contents:
-----BEGIN--------------------------------------------------------------
---------------  T H R E A D  ---------------
Current thread (0x00007ff9f407f000):  JavaThread "Thread-108" [_thread_in_native, id=23984, stack(0x00007ff9ebd9d000,0x00007ff9ebe9e000)]
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0xffffffffebe9c668
Registers:
RAX=0xffffffffebe9c660, RBX=0x000000000000001f, RCX=0x0000000000000001, RDX=0x00007ffa60198000
RSP=0x00007ff9ebe9bd60, RBP=0x00000000ffffffff, RSI=0x00007ff9ec0ab980, RDI=0x00007ff9ec0ab88a
R8 =0x0000000000000ffc, R9 =0x00007ffa5f69f828, R10=0x00007ffa5f6a3538, R11=0x00007ffa5f6977e0
R12=0x00007ff9f407f000, R13=0x00007ff9fa1c0788, R14=0x00007ff9ebe9bf40, R15=0x00007ff9f407f000
RIP=0x00007ff9ec0a9333, EFL=0x0000000000010202, CSGSFS=0x0000000000000033, ERR=0x0000000000000005
 TRAPNO=0x000000000000000e
Top of Stack: (sp=0x00007ff9ebe9bd60)
0x00007ff9ebe9bd60:   00007ff9f407f000 00007ff9fa1c8008
0x00007ff9ebe9bd70:   00007ff9f407f000 00007ff9ec0abdc3
0x00007ff9ebe9bd80:   00007ff9ec0ab982 00000000408205b8
0x00007ff9ebe9bd90:   00000001ffffffff 00007ff9ebe9beb7
0x00007ff9ebe9bda0:   0000001febe9bdf0 00007ff9f43ef1b8
0x00007ff9ebe9bdb0:   00007ff9f43ef1b0 00007ff9f43ef1a8
0x00007ff9ebe9bdc0:   000000b400000002 ffffffffebe9c660
0x00007ff9ebe9bdd0:   0000000000000040 00007ffa0000008c
0x00007ff9ebe9bde0:   00007ff9f43ef1c0 00007ffa5f68dd70
0x00007ff9ebe9bdf0:   00007ff9f407f000 0000000000000000
0x00007ff9ebe9be00:   00007ff9f407f000 0000000000000000
0x00007ff9ebe9be10:   00007ff9f407f000 00007ffa5f34c5ca
0x00007ff9ebe9be20:   00007ff9f407f000 000000b65f096521
0x00007ff9ebe9be30:   00007ff9f407f000 00007ff9ec0ab982
0x00007ff9ebe9be40:   00007ff9f407f000 00007ff9ebe9bf40
0x00007ff9ebe9be50:   00000000ffffffff 00000000408205b8
0x00007ff9ebe9be60:   00007ff9f407f1b8 000000000000001f
0x00007ff9ebe9be70:   00007ff9f407f1b8 00007ff9f407f000
0x00007ff9ebe9be80:   00007ff9fa1c0788 00007ff9ebe9bf40
0x00007ff9ebe9be90:   00007ff9f407f000 00007ff9ec0a9908
0x00007ff9ebe9bea0:   00007ff9ebe9bf40 00007ff9f407f000
0x00007ff9ebe9beb0:   00007ff9ebe9bf20 00007ff9fa1c0790
0x00007ff9ebe9bec0:   00007ff9ebe9bf20 00007ffa5abc3f50
0x00007ff9ebe9bed0:   00007ff9f407f000 00007ffa5abce3a3
0x00007ff9ebe9bee0:   00007ff9ebe9bee0 00007ff9fa1c0788
0x00007ff9ebe9bef0:   00007ff9ebe9bf40 00007ff9fa4c1ae8
0x00007ff9ebe9bf00:   0000000000000000 00007ff9fa1c0790
0x00007ff9ebe9bf10:   0000000000000000 00007ff9ebe9bf40
0x00007ff9ebe9bf20:   00007ff9ebe9bf98 00007ffa5abb890e
0x00007ff9ebe9bf30:   0000000000000000 00007ffa5abc0a56
0x00007ff9ebe9bf40:   00007ffa3cba20b0 00007ff9f43a7948
0x00007ff9ebe9bf50:   00007ffa3cba2180 00007ff9ebe9bf48
Instructions: (pc=0x00007ff9ec0a9333)
0x00007ff9ec0a9323:   24 30 e8 46 cc ff ff 8b 6c 24 30 48 89 44 24 68
0x00007ff9ec0a9333:   8b 40 08 48 8b 54 24 68 48 c7 44 24 58 00 00 00
Stack: [0x00007ff9ebd9d000,0x00007ff9ebe9e000],  sp=0x00007ff9ebe9bd60,  free space=1019k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  gnu.io.RXTXPort.readByte()I+0
j  gnu.io.RXTXPort$SerialInputStream.read()I+61
j  processing.app.Serial.serialEvent(Lgnu/io/SerialPortEvent;)V+114
j  gnu.io.RXTXPort.sendEvent(IZ)Z+382
v  ~StubRoutines::call_stub
j  gnu.io.RXTXPort.eventLoop()V+0
j  gnu.io.RXTXPort$MonitorThread.run()V+12
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
=>0x00007ff9f407f000 JavaThread "Thread-108" [_thread_in_native, id=23984, stack(0x00007ff9ebd9d000,0x00007ff9ebe9e000)]
 0x00000000406aa800 JavaThread "DestroyJavaVM" [_thread_blocked, id=23697, stack(0x00007ffa5ea53000,0x00007ffa5eb54000)]
 0x0000000040bf9800 JavaThread "TimerQueue" daemon [_thread_blocked, id=23715, stack(0x00007ff9ebe9e000,0x00007ff9ebf9f000)]
 0x0000000040aad000 JavaThread "AWT-EventQueue-0" [_thread_in_native, id=23713, stack(0x00007ff9ec2b0000,0x00007ff9ec3b1000)]
 0x0000000040aac000 JavaThread "AWT-Shutdown" [_thread_blocked, id=23712, stack(0x00007ff9ec3b1000,0x00007ff9ec4b2000)]
 0x0000000040845000 JavaThread "AWT-XAWT" daemon [_thread_blocked, id=23711, stack(0x00007ff9f22d4000,0x00007ff9f23d5000)]
 0x000000004071e800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=23710, stack(0x00007ff9f29ee000,0x00007ff9f2aef000)]
 0x00000000406c4800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=23708, stack(0x00007ff9f80ad000,0x00007ff9f81ae000)]
 0x00007ff9f4076000 JavaThread "CompilerThread1" daemon [_thread_blocked, id=23707, stack(0x00007ff9f81ae000,0x00007ff9f82af000)]
 0x00007ff9f4074000 JavaThread "CompilerThread0" daemon [_thread_blocked, id=23706, stack(0x00007ff9f82af000,0x00007ff9f83b0000)]
 0x00007ff9f4072000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=23705, stack(0x00007ff9f83b0000,0x00007ff9f84b1000)]
 0x00007ff9f4054000 JavaThread "Finalizer" daemon [_thread_blocked, id=23704, stack(0x00007ff9f84f0000,0x00007ff9f85f1000)]
 0x00007ff9f4052000 JavaThread "Reference Handler" daemon [_thread_blocked, id=23703, stack(0x00007ff9f85f1000,0x00007ff9f86f2000)]
Other Threads:
 0x00007ff9f404b000 VMThread [stack: 0x00007ff9f86f2000,0x00007ff9f87f3000] [id=23702]
 0x00000000406c7000 WatcherThread [stack: 0x00007ff9f3eff000,0x00007ff9f4000000] [id=23709]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen      total 27520K, used 12769K [0x00007ffa3bfb0000, 0x00007ffa3de60000, 0x00007ffa5abb0000)
 eden space 23616K, 54% used [0x00007ffa3bfb0000,0x00007ffa3cc28648,0x00007ffa3d6c0000)
 from space 3904K, 0% used [0x00007ffa3da90000,0x00007ffa3da90000,0x00007ffa3de60000)
 to   space 3904K, 0% used [0x00007ffa3d6c0000,0x00007ffa3d6c0000,0x00007ffa3da90000)
PSOldGen        total 62976K, used 12167K [0x00007ff9fe7b0000, 0x00007ffa02530000, 0x00007ffa3bfb0000)
 object space 62976K, 19% used [0x00007ff9fe7b0000,0x00007ff9ff391e68,0x00007ffa02530000)
PSPermGen       total 37824K, used 17555K [0x00007ff9f93b0000, 0x00007ff9fb8a0000, 0x00007ff9fe7b0000)
 object space 37824K, 46% used [0x00007ff9f93b0000,0x00007ff9fa4d4e50,0x00007ff9fb8a0000)
Dynamic libraries:
40000000-40009000 r-xp 00000000 08:01 7020612                            /usr/lib/jvm/java-6-sun-1.6.0.16/jre/bin/java
40108000-4010a000 rwxp 00008000 08:01 7020612                            /usr/lib/jvm/java-6-sun-1.6.0.16/jre/bin/java
406a2000-40d59000 rwxp 406a2000 00:00 0                                  [heap]
7ff9eb365000-7ff9eb4e2000 rwxs 00000000 00:09 4816916                    /SYSV00000000 (deleted)
7ff9eb503000-7ff9eb506000 rwxp 7ff9eb503000 00:00 0
7ff9eb506000-7ff9eb604000 rwxp 7ff9eb506000 00:00 0
7ff9eb604000-7ff9eb607000 rwxp 7ff9eb604000 00:00 0
7ff9eb607000-7ff9eb705000 rwxp 7ff9eb607000 00:00 0
7ff9eb705000-7ff9eb765000 rwxs 00000000 00:09 4718611                    /SYSV00000000 (deleted)
7ff9eb765000-7ff9eb779000 r-xp 00000000 08:01 29843577                   /lib/libresolv-2.9.so
7ff9eb779000-7ff9eb979000 ---p 00014000 08:01 29843577
Thanks,
Byron
funziona
Hey
Check http://feelslikeburning.com/2009/08/21/how-to-get-arduino-0017-working-on-64-bit-linux-including-ubuntu-9-04/
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
