Topic: Is it possible to upload arduino bootloader to atmega128? (Read 2553 times) previous topic - next topic
bianchi
Mar 25, 2014, 11:32 pm Last Edit: Mar 26, 2014, 07:04 am by bianchi Reason: 1
Guys,
Which version of arduino should I use ?
I have UsbAsp, can I use it ? How ? I can only upload *.hex file directly from USBasp uploader, but not yet successful on uploading via arduino 1.5 IDE
how can I customize the pin out, as I like ?
which file should I ponder ?
I saw pin_arduino.h but I 'm not sure on how to configure it ??
Any references ?
thanks
pylon
Quote
Not unchanged but with some adaption this should be no problem.
Quote
The latest stable, which is 1.0.5
Quote
You have to modify boards.txt and add an entry for your ATmega128 board there.
Quote
What do you mean by that? Changing the translation from the Arduino pin numbering to the actual ports?
Quote
You don't have to change it but to make a new variant, so create a new directory for your variant and copy pin_arduino.h there and modify that copy. You have to modify it according to the pinout you've chosen.
bianchi
Quote
How can I modify pin_out.h, is there any references ? thanks
pylon
Quote
In the variants directory there are many examples for the existing Arduino models, the reference for it is in the datasheet of the processor. If you mean that you're looking for a step-by-step guide, no, this doesn't exist, because such a task is nothing for a beginner and an experienced Arduino user doesn't need one.
