Topic: PB2 not defined (Read 6616 times) previous topic - next topic
enzo
Hi
I'd like to write to an SD card and the reference is the library: http://www.roland-riegel.de/sd-reader/index.html
I've change the code a little, in fact exactly the same way as others in the forum have done to create a new SD library from this lib
So i've changed 4 define in sd_raw_config.h:
#define configure_pin_available() 0
#define configure_pin_locked() 0
#define get_pin_available() 0
#define get_pin_locked() 0
and added a defined(__AVR_ATmega328P__) (I've feedbacked roland to support this new uC)
=> It would compile perfectly if PB2 was defined, it's in fact a keyword in arduino, however I've never found a #define PB2 somewhere in the code
Last thing, PB2 has always been defined in roland lib and, it used to compile nicely before
So maybe arduino code has changed on this PB2 ? no more a keyword ? it would be nice to define it again for compatibility
PB2 seems to be the SPI pin /SS (Slave Select pin)
I think it's 10 according to http://www.arduino.cc/en/Tutorial/SPIEEPROM
enzo
Hi again
In fact I've found #define PB2 in avr-libc package
I'm using ubuntu 8.10 and as avr is broken, i use ubuntu 9.04 (jaunty) packages, that are:
ii  avr-libc                                                       1:1.6.2.cvs20080610-2    Standard C library for Atmel AVR development
ii  binutils-avr                                                   2.18-4ubuntu1    Binary utilities supporting Atmel's AVR targ
ii  gcc-avr                                                        1:4.3.2-1    The GNU C compiler (cross compiler for avr)
Anyone has ever compiled whatever SD lib for a 328p ? (all sd lib are based on roland lib)
enzo
I answer to myself again
In fact this problem concerns avr and roland lib, arduino has nothing to do in it
I can compile with no problem the lib of rolande for an ATmega168, but no way for a 328p, because of the lack of PB2 defined, as it's used in sd_raw_config.h
Sorry for disturbance, i contact directly Roland Riegel
Cheers
enzo
Hi again again,
I've been able to compile roland lib SD card now, except fat.c, 2 errors again
For information, i've changed *.c => *.cpp
i've added in sd_raw_config.h in the big test:
#elif defined(__AVR_ATmega328P__)
   #define configure_pin_mosi() DDRB |= (1 << DDB3)
   #define configure_pin_sck() DDRB |= (1 << DDB5)
   #define configure_pin_ss() DDRB |= (1 << DDB2)
   #define configure_pin_miso() DDRB &= ~(1 << DDB4)
   #define select_card() PORTB &= ~(1 << PINB2)
   #define unselect_card() PORTB |= (1 << PINB2)
and changed:
#define configure_pin_available() DDRC &= ~(1 << DDC4)
#define configure_pin_locked() DDRC &= ~(1 << DDC5)
#define get_pin_available() ((PINC >> PC4) & 0x01)
#define get_pin_locked() ((PINC >> PC5) & 0x01)
into:
#define configure_pin_available() //DDRC &= ~(1 << DDC4)
#define configure_pin_locked() //DDRC &= ~(1 << DDC5)
#define get_pin_available() 0 //((PINC >> PC4) & 0x01)
#define get_pin_locked() 0 //((PINC >> PC5) & 0x01)
But as I said, i still have 2 errors when compiling fat.c in arduino (but the lib compiles perfectly now with 328p with the Makefile) :
fat.cpp: In function 'uint8_t fat_dir_entry_read_callback(uint8_t*, offset_t, void*)':
fat.cpp:1491: error: invalid conversion from 'void*' to 'fat_read_dir_callback_arg*'
fat.cpp: In function 'offset_t fat_get_fs_free(const fat_fs_struct*)':
fat.cpp:2250: error: 'UINTPTR_MAX' was not declared in this scope
If anyone has an idea to how to resolve these last 2 errors, I would be very interested !!
westfw
PB2 is normally defined in the hierarchy of files included via <avr/io.h>;
In the 168 case, this includes <avr/iom168.h>, which includes <avr/iomx8.h> (definitions common to all Atmega*8), which actually defines PB2.
For the 328, assuming you have a recent compiler installed, the equivalent <avr/iom328.h> does NOT include <avr/iomx8.h>, nor does it define PB2.  I don't know why.
enzo
Yes I've seen that
And I've stolen the patch applied in AF_Wave
That is, no more use PB2, but PINB2 instead, and it compiles
Except the last errors
Roland has answered me on the fact it's a nonsense to just rename fat.c in fat.cpp
However, Every lib I've seen on arduino to write on SD, just do this very bad thing...
wholder
I've been trying to figure this out, too.  The value of UINTPTR_MAX is defined in:
 ..\hardware\tools\avr\avr\include\stdint.h
and this file is included by Roland's fat.h file.  So, it's puzzling to me that this value is not picked up by the compiler...
I'd like to know the correct way to fix this but, in the end, I got the code to compile by replacing the value with 0xFFFE, which is what I believe the compiled value of UINTPTR_MAX - 1 would be.
Wayne
wholder
BTW, on the issue of why PB2 is not defined for the 328P, it appears that the include file io.h has a series of conditionals, like this:
#elif defined (__AVR_ATmega328P__)
#  include <avr/iom328p.h>
#elif defined (__AVR_ATmega168__)
#  include <avr/iom168.h>
that select the proper include file based on the processor type.  The file avr/iom168.h #includes avr/iomx8.h which, in turn, contains  #defines for both PINBn and PBn values.  However, the file avr/iom328p.h seems to contain only #defines for PINBn values.
It appears that the design of the avr/iom328p.h makes it more of a standalone file that includes definitions for both pins and fuses whereas the avr/iom168.h defines fuse values and then includes avr/iomx8.h to define the pins.
However, I notice that there is also a file named  avr/iom168p.h that is in the same combined style as avr/iom328p.h.  But, apparently, this file is not selected when compiling for a 168-based Arduino.  I'm new to the AVR family, so I find this all a bit confusing, but perhaps it makes sense to someone else...
Wayne
wholder
#8
Mar 24, 2009, 06:12 pm Last Edit: Mar 25, 2009, 08:19 am by wholder Reason: 1
In looking over stdint.h, I finally noticed that the code contains this conditional:
#if !defined(__cplusplus) || defined(__STDC_LIMIT_MACROS)
Since I also converted Roland's .c files to .cpp to get them to compile and link, it looks like this change broke the ability to reference the values in stdint.h.  So, to fix it, I added a:
#define __STDC_LIMIT_MACROS      1
at the top of fat.cpp.
Wayne
Windell Oskay
Quote
No-- don't do that.  PB2 is meant to represent output, while PINB2 is meant to represent input.  Change it to PORTB2 or just to the number '2' but DO NOT change it to PINB2.
sirus20x6
this looks like the thread I need as I came from http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1206874649/8 with the same errors you guys are reporting. tried to implement your changes
Code: [Select]
   defined(__AVR_ATmega168__)
   #define select_card() PORTB &= ~(1 << PB2)
   #define unselect_card() PORTB |= (1 << PB2)
  #define select_card() PORTB &= ~(1 << PORTB2)
  #define unselect_card() PORTB |= (1 << PORTB2)
and
Code: [Select]
but I get
Code: [Select]
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:13: error: 'byte' does not name a type
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:16: error: 'byte' does not name a type
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp: In function 'void setup()':
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:22: error: 'Serial' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:23: error: 'delay' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp: In function 'void loop()':
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:39: error: 'Serial' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:41: error: 'incomingByte' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp: In function 'int sample()':
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:61: error: 'byte' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:61: error: expected `;' before 'low'
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:62: error: expected `;' before 'high'
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:63: error: expected `;' before 'inByte'
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:65: error: 'Serial' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:72: error: 'inByte' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:75: error: 'analogRead' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:76: error: 'DEC' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:80: error: 'low' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:81: error: 'high' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:86: error: 'tempBytes' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:94: error: 'delay' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp: In function 'int readDisk()':
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:106: error: 'byte' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:106: error: expected `;' before 'low'
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:107: error: expected `;' before 'high'
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:108: error: expected `;' before 'info'
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:111: error: 'Serial' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:114: error: 'info' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:119: error: 'low' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:120: error: 'high' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:124: error: 'DEC' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp: In function 'void printWelcome()':
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:132: error: 'Serial' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp: In function 'int print_disk_info()':
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:153: error: 'Serial' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:155: error: 'HEX' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:161: error: 'DEC' was not declared in this scope
any ideas?
how about if anyone has the library with modifications that I can download so I know I didn't mess up what I was supposed to patch?
Thanks a bunch
sirus20x6
ok fixed the byte errors with
Code: [Select]
#define byte uint8_t
but i still get
Code: [Select]
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:23: error: 'Serial' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:24: error: 'delay' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:40: error: 'Serial' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:66: error: 'Serial' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:76: error: 'analogRead' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:77: error: 'DEC' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:95: error: 'delay' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:112: error: 'Serial' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:125: error: 'DEC' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:133: error: 'Serial' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:154: error: 'Serial' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:156: error: 'HEX' was not declared in this scope
/home/sirus/arduino/hardware/libraries/SDcard/arduino sd card example.cpp:162: error: 'DEC' was not declared in this scope
follower
I think you need to include this (or something similar) at the start of the file:
Code: [Select]
#include "WProgram.h"
--Philip;
sirus20x6
thanks for the reply but there is no change. also the IDE seems to be really really really buggy. I can only save a sketch once and then it gets set to read only. trying to save again gives me an error message. going into windows explorer and changing the permissions doesnt work as the ide sets them right back to read only. every time i have to save a new sketch to a new directory and delete the old one. my IDE doesnt even resize correctly I get black bars. I've tried on 3 different computers. 1 ubuntu and 2 windows 7. is 17 just a buggy build? should i go to 16?
madworm
I can't speak for windoze, but 017 runs quite OK on linux.
The missing PB2 or PORTB2 definitions are caused by
Code: [Select]
../include/avr/portpins.h
The windows version of 017 comes with an older version of avr-libc that still has that problem. Later versions of avr-libc have it fixed.
The fixed version of that file has entries like
Code: [Select]
#if defined(PB2) && !defined(PORTB2)
#  define PORTB2 PB2
#elif defined(PORTB2) && !defined(PB2)
#  define PB2 PORTB2
#endif
which works both ways. Half of that is missing in 017 on windows.
• Upload doesn't work? Do a loop-back test.
• There's absolutely NO excuse for not having an ISP!
• Your AVR needs a brain surgery? Use the online FUSE calculator.
My projects: RGB LED matrix, RGB LED ring, various ATtiny gadgets...
• Microsoft is not the answer. It is the question, and the answer is NO!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
