Topic: PB2 not defined (Read 7430 times) previous topic - next topic
sirus20x6
i think i have the pb2 and portb2 stuff figured out but what cant it figure out what Serial HEX DEC and that stuff is? works with simple sketches but now when i try to build anything complicated like this
sirus20x6
anyone get this working?
sirus20x6
dingbatca
I am also looking for a fix to this issue
dingbatca
ok, I took a different approach.  Working great in windows, with a 328 chip on V17.
First, you are going to need the working code :-) God bless GPL!
http://github.com/nseidle/OpenLog/tree/master/Code/
Grab sd_raw.c sd_raw.h, sd_raw_config.h
rename sd_raw.c to sd_raw.cpp
Place those 3 files in a new libraries file.  Mine looks like this "C:\Program Files (x86)\arduino-0017\hardware\libraries\sdcard"
And all 3 are in the "sdcard" dir.
Time for hello world!
Code: [Select]
#include "sd_raw_config.h"
#include "sd_raw.h"
 sd_raw_init();
 struct sd_raw_info disk_info;
 if(!sd_raw_get_info(&disk_info))
     //return 0;
 Serial.print("rev:    ");
 Serial.print(disk_info.revision,HEX);
 Serial.print("serial: 0x");
 Serial.print(disk_info.serial,HEX);
 Serial.print("date:   ");
 Serial.print(disk_info.manufacturing_month,DEC);
 Serial.print(disk_info.manufacturing_year,DEC);
 Serial.print("size:   ");
 Serial.print(disk_info.capacity,DEC);
 Serial.print("copy:   ");
 Serial.print(disk_info.flag_copy,DEC);
 Serial.print("wr.pr.: ");
 Serial.print(disk_info.flag_write_protect_temp,DEC);
 Serial.print('/');
 Serial.print(disk_info.flag_write_protect,DEC);
 Serial.print("format: ");
 Serial.print(disk_info.format,DEC);
 Serial.print("free:   ");
 delay(10000);
You should see something like this show up:
Code: [Select]
rev:    3
serial: 0x3032057D
date:   7
5
copy:   0
wr.pr.: 0/0
format: 0
free:   1
Next on the list.. Round Robin FS(RRFS)!
delse
Hi.  I've read through everyone's postings, and I'm down to just this one error -- which I can't find a solution to.  Has anyone figured this one out?  Thanks much!!!
C:\Desktop\Arduino\arduino-0018\libraries\SDcard\fat.cpp: In function 'uint8_t fat_dir_entry_read_callback(uint8_t*, offset_t, void*)':
C:\Desktop\Arduino\arduino-0018\libraries\SDcard\fat.cpp:1555: error: invalid conversion from 'void*' to 'fat_read_dir_callback_arg*'
delse
Okay, following up on my own question.  The problem seems to be that renaming fat.c to fat.cpp actually creates more problems then it solves.  A better way (in my opinion) is to leave it named fat.c and fix all the "for loop" errors by moving the variable declarations outside the loop.  After doing this, I am now able to compile....
