Loading...
Pages: [1]   Go Down
Author Topic: Is this a bug or am I missing something?  (Read 345 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
This never evaluates to true and the code inside the if statement does not get executed.  However when I serial.print the values in the if statement, the values are AP==-3, AC==30 and val == 35.  The only thing I can see that might be an issue is that AP is signed and a negative value where the other values are unsigned.  Is it not possible to compare signed and unsigend integers?
unsigned int val = 35;
unsigned int AC = 30;
int AP = -3;
if (val==35 && AP < AC){
  //do something
Logged
Norway
Offline Offline
Newbie
Arduino rocks
View Profile
See:
http://c-faq.com/expr/preservingrules.html
In short "To avoid surprises (under either set of rules, or due to an unexpected change of rules), it's best to avoid mixing signed and unsigned types in the same expression"
PS: Edit: g++ with -Wall args warns about this. I would like to have such warnings present in Arduino Uno Punto Zero
« Last Edit: April 03, 2010, 06:23:22 pm by hakoni » Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Yeah, I think you are getting unsigned arithmetic.
Try saying
if (val==35 && AP < (int)AC){
Logged
Norway
Offline Offline
Sr. Member
microscopic quantum convulsions of space-time
View Profile
WWW
Or try
int AP = -3;
if (val==35 && AP [glow]>[/glow] AC){
 //do something
for the sake of testing, not that it is too useful smiley
(As in, what is -3 binary,and what is this binary if it was unsigned?)
brtech's way is better of course, as long as the unsigned int's value is below 32768.
Nice link hakoni!
I got a little curious and skimmed through the atmega 328 assembler instructions. I find a lot of branch-if instructions, but no BRHI (or similar; branch if higher, unsigned). Only BRHS (branch if same or higher, unsigned I presume), and a lot of other signed and unsigned variations. Seems strange as one would have to combine at least two different tests for such a simple test, when the atmega have so many instructions. Unless I misunderstand and some of the other branch instructions are equivalent of a BRHI.
So, any assembler people here that know how an unsigned "branch if higher than" test is performed on atmega 328 at that level? Just curious, not that I will dabble in atmega assembler for a good while yet.
Logged
Pages: [1]   Go Up
Print
Jump to:
