Topic: an shield to talk with her (Read 1 time) previous topic - next topic
xevilstar
I would like to know what it takes to make a device to connect to a linux computer that using my netcom legal regular sim card out of my mobile can allow me to use the headphones and microphone of the pc to make normal mobile phonecalls to my wife/friends (no voip).  I would like to use my duemilanove..... can it be a shield ?
what is necessary to do software side on the pc ?
cr0sh
What is necessary will be "a lot", if I understand your question correctly. First, you would need to build your own shield (I don't think there exists a "cell phone" shield, but who knows?); I do know that SparkFun sells cellular modules that can use your sim card:
http://www.sparkfun.com/commerce/categories.php?c=66
Note that many of them aren't cheap; but, several (seem?) to not require anything more than a USB connection, but that may be data only, and not audio. In fact, I am not sure which would allow for you to use the PC (or the PC via an Arduino) to send the AT dialing commands and such (I presume this is what you want to do), then allow the voice/headset to be used to talk over the cellular module like a cell phone. You'll have to review them.
Beyond that, you would then need software on the PC side that could allow the selection (in some manner) of the phone number to dial, then send that via USB to the Arduino (or directly to the module), which would then interpret it and send/use the appropriate AT commands (or whatver protocol) to cause the module to dial and conncect; it would also have to monitor the status, so it knows if the call is connected, failed to connect, and/or what the signal strength is before, during, and after the call.
Sounds like an ambitious project, but certainly doable if you don't mind spending more money than it would cost to buy a cheapo TracFone...
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
musica
Hi,I am new to this site ,very useful information,thanks for this site.
xevilstar
is there any expert here willing to design the cellphone shield for the world to use ?
laxman098
natman3400
Sparkfun has a cell sheild. Look under the arduino section
xevilstar
natman3400
If you hook spmething up to the mic and speaker pins of it, yes, yes you can.
anachrocomputer
There is a shield that can be used with the Arduino and a SIM to make GSM calls and send/receive SMS texts. It's called the GSM Playground:
http://www.hwkitchen.com/products/gsm-playground/
I've used it for SMS, but not for voice calls. You'll need to buy the LiPO battery with it, and a suitable GSM antenna.
