Alfeld (Leine) / Germany
Offline
Full Member
« on: December 20, 2009, 07:51:08 am » |
Hello, Arduino Community. First sorry for my bad english... I found a way to add an USB port to any 5 volt arduino: You have to buy a Nokia DKU-5 datacable USB, you can find it on e*ay for only 1 dollar or euro. It has to be this one:  You only have to cut the PopPort on the Cable and Connect 5v gnd rx tx to your arduino. Greets tobi31061 EDIT: Here are the working drivers for the TI Chip: http://segaemu.bplaced.net/DISK1.rar
« Last Edit: December 20, 2009, 01:28:07 pm by tobi31061 »
Logged
ottawa, canada
Offline
God Member
Arduino rocks
« Reply #1 on: December 20, 2009, 10:54:05 am » |
Nice find. Thank you.
Logged
Offline
Full Member
« Reply #2 on: December 20, 2009, 01:27:20 pm » |
NP. And i also found a cheap way to connect my calculator to my pc with this cable. ;D
Logged
SF Bay Area (USA)
Offline
Faraday Member
Strongly opinionated, but not official!
« Reply #3 on: December 21, 2009, 08:28:33 pm » |
Also works with CA-42 type cables (about the same price. Less than $3 shipped.) There is a nice tutorial here: http://www.uchobby.com/index.php/2009/10/04/diy-usb-to-serial-cable-for-3/The CA-42 seems to be based on the Prolific USB/Serial chip rather than the TI, and the prolific seems to have a larger userbase and be supported on more platforms. (I've yet to find Mac support for either the DKU-5 or other devices containing a TI USB/Serial chip. Sigh.)
Logged
Offline
God Member
Arduino rocks
« Reply #4 on: December 22, 2009, 02:56:37 am » |
There appears to be a confusing mix of 5V/3V3 versions of these cables (or at least Google suggests this is the case). How did you wire it for 5V Arduino's (pin number/color on DKU-5 connector)? I've converted a couple CA-42 type cables and they work ok for Rx/Tx and 5V USB bus power (no DTR/RTS for auto-reset however) . This required prying open the USB connector and soldering a wire directlly onto an SMD pin which is tricky. Perhaps your find is eaiser to convert. The prolific chip used in the CA-42 was indeed a 5V tolerant chip and I wonder if this is so for the DKU-5 as well.
« Last Edit: December 22, 2009, 02:57:52 am by borref »
Logged
0
Offline
Newbie
Arduino rocks
« Reply #5 on: December 22, 2009, 12:45:48 pm » |
Hello everyone
I'm just posting this one message so I'll be allowed to post links and images.
Matt
Logged
0
Offline
Newbie
Arduino rocks
« Reply #6 on: December 22, 2009, 12:46:35 pm » |
« Last Edit: December 22, 2009, 12:47:06 pm by 1315matthew »
Logged
Offline
Full Member
« Reply #7 on: December 23, 2009, 04:17:06 am » |
Very nice to hear that this worked for you, but btw, my multimeter is broken i have problems with checking out the lines....
do somebody now the pins? it has brown orange green yellow red
Logged
UK
Offline
God Member
« Reply #8 on: January 20, 2010, 03:03:46 am » |
Ordered my one from the same place, came in the same box, but has 5 core wire. Black: GND Blue: TX White: RX Green: VCC Ps what order should theses be soldered to a 6 pin header? Im guessing 1: GND 2: 3: VCC 4: TX 5: RX 6:
Logged
Offline
God Member
Arduino rocks
« Reply #9 on: January 20, 2010, 04:25:30 am » |
The "modified" FTDI cable (as used by SparkFun and others) is wired as follows:
1: GND - GND 2: 3: VCC - VCC 4: Pin 2 on MCU (AtMega RXD) 5: Pin 3 on MCU (AtMega TXD) 6: DTR to RESET on MCU
1 is referred to as the "black wire" and 6 as the "green wire" in some references (e.g. on Pro Mini boards).
Logged
UK
Offline
God Member
« Reply #10 on: January 20, 2010, 05:01:53 am » |
DTR to RESET on MCU so.......... A: How do you determine what wire is the RESET on a DKU-5? B: What are the ramifications of using the 3 core cable with just VCC/TX/RX?
« Last Edit: January 20, 2010, 05:02:58 am by n00b »
Logged
Offline
God Member
Arduino rocks
« Reply #11 on: January 20, 2010, 07:48:14 am » |
A: How do you determine what wire is the RESET on a DKU-5? You trace the wire back to the chip and check against the chip's datasheet (or Google for relevant sources). There apperars to be as many variations on this cable however as there are suppliers.
B: What are the ramifications of using the 3 core cable with just VCC/TX/RX? I doubt you will ever find such a cable. The 3 wire GND/RX/TX however will enable Arduino to USB serial communication, but without auto-reset or power from USB.
Logged
SF Bay Area (USA)
Offline
Faraday Member
« Reply #12 on: January 20, 2010, 11:36:46 am » |
B: What are the ramifications of using the 3 core cable with just VCC/TX/RX? I doubt you will ever find such a cable. The 3 wire GND/RX/TX however will enable Arduino to USB serial communication, but without auto-reset or power from USB. For people who are too new to remember, no auto-reset means that when attempting to upload a sketch to the arduino, you have to manually push the "RESET" button at nearly the same time you hit the "upload" button. It's not a big deal... All of the CA-42 cables I've seen seem to be of the 3-wire variety.
Logged
UK
Offline
God Member
« Reply #13 on: January 20, 2010, 02:26:57 pm » |
Done a little research on the pin out of the Nokia Pop-port, so if anyone is lucky enough to get the 5 wire DKU-5 (like me  ), grab your multimeter, strip the wires to the DKU-5 header, and use the diode setting to find out what colour wire correspond to what header pin.
« Last Edit: January 20, 2010, 02:31:51 pm by n00b »
Logged
B0100111001000011, USA
Offline
Edison Member
I'm confused. Wait, maybe not..
« Reply #14 on: January 23, 2010, 06:57:28 pm » |
There's a nice tutorial out there somewhere for the same thing  . I doubt you will ever find such a cable. The 3 wire GND/RX/TX however will enable Arduino to USB serial communication, but without auto-reset or power from USB. I just did the same thing with a CA-42 cable (very similar to DKU-5), and there were only those three wires. I had to run a third down the length of the cable for +5V Vcc, but it works great now  .
Logged
