Topic: Strange error just editing code in 0019 (Read 1 time) previous topic - next topic
juliandasilva
Hi, I was working on the following Skecth:
Quote
#include <DCMotor.h>
motor0.setClockwise(true);
motor0.setClockwise(false);
motor0.setSpeed(50.0);
motor1.setSpeed(50.0);
delay(5000);
motor0.brake();
motor1.setSpeed(0);
motor0.setSpeed(-90.0);
motor1.setSpeed(-45.0);
delay(5000);
motor0.setSpeed(0);
motor1.setSpeed(0);
And just open it and I get the following errors:
Error repainting line range {0,19}:
java.lang.ArrayIndexOutOfBoundsException: 55
at processing.app.syntax.SyntaxUtilities.paintSyntaxLine(Unknown Source)
at processing.app.syntax.TextAreaPainter.paintSyntaxLine(Unknown Source)
at processing.app.syntax.TextAreaPainter.paintLine(Unknown Source)
at processing.app.syntax.TextAreaPainter.paint(Unknown Source)
at javax.swing.JComponent.paintChildren(JComponent.java:864)
at javax.swing.JComponent.paint(JComponent.java:1038)
at javax.swing.JSplitPane.paintChildren(JSplitPane.java:1030)
And continues.
This does not happend when I open the same pde in the 0018 IDE.
Regards,
Julián
http://robotgroup.com.ar
juliandasilva
Well, I found the cause, but I still think it's a bug (the editor only showed text until the bad keyword, and then all that streaming with the long error text started).
The problem was that there was a bad formated keywords.txt file in another library. I fixed it, and the problem disapeared. In my 0018 it did not happen because that library was not installed.
