Topic: delay inconsistent between ver 0018 and 0019 (Read 2859 times) previous topic - next topic
garry572
Sep 15, 2010, 11:36 am Last Edit: Sep 15, 2010, 11:40 am by garry572 Reason: 1
I have a simple loop using analogwrite function to vary the brightness of a LED, followed by a delay
analogWrite(ledPin, 0);
   analogWrite(ledPin, 15);
   analogWrite(ledPin, 30);
   analogWrite(ledPin, 60);
   analogWrite(ledPin, 80);
   analogWrite(ledPin, 100);
   analogWrite(ledPin, 128);
   analogWrite(ledPin, 255);
If I compile with version 0018 of the IDE, the time between steps seems much less than 1 sec and seem to vary significantly
Compiling with 0019 , no code change, the steps are consistent and close to ! sec
mowcius
Quote
Oh good. Maybe 0019 is an improvement then.
Mowcius
Jeff K
IIRC there were updates in 0019 to the delay functions to address the issues in 0018.  So this behavior is expected between the 2 versions.
Jeff K - JKDevices.com - home of the MegaMini
Jeff K
A quick look at the release notes for 0019 and you have your answer...
Quote
* More accurate delay() function from BenF.
 http://code.google.com/p/arduino/issues/detail?id=237
westfw
The new delay should be accurate near the microseconds scale.  The old delay() ought to be been accurate to within a millisecond or so, which should have been imperceptible in a 1000ms delay on a blinking LED, but was somewhat problematic when delay(1) was almost always 2ms long...
Something else may be going on here...
(which pin are you using for the LED?  I wonder if there were unexpected interactions between the timer used for that pin's AnalogWrite and the timer used for milis())
garry572
I  suspect that might be the problem, I thought I checked but..
I'm using a 328, pin D9 for the LED.
I assumed the timing error would be within a few counts, but it seems to var from 100mSec up  to 1 sec.
I will try another pin to see if I can reproduce the error
westfw
I could not duplicate the problem here (on a 168, using the pin13 LED between each set of analogWrites...)
garry572
I think I might a a strange hardware issue with the board I tried it on, I used another 328 and it was fine
mowcius
Quote
Hmm, strange...
