I just had a look at the pins used by the Ethernet SD shield (the currently latest version) and found this documentation
http://www.arduino.cc/playground/Main/ShieldPinUsagewhere it says that the shield uses pins 10, 11, 12, 13.
However, in the introduction of the shield
http://arduino.cc/en/Main/ArduinoEthernetShieldit says:
"Arduino communicates with both the W5100 and SD card using the SPI bus (through the ICSP header). This is on digital pins
11, 12, and 13 on the Duemilanove..."
"If you're not using one of the peripherals in your program, however, you'll need to explicitly deselect it. To do this with the SD card, set pin
4 as an output and write a high to it. For the W5100, set digital pin
10 as a high output."
So if I understand this correctly, pins 4 and 10 are used to turn either the SD part or the ethernet part on or off.
So if pin 10 per definition is a used one, shouldn't be pin 4 declared as used too?
The question came up because I'm running out of pins soon and have to start bean counting.
