Loading...
Pages: 1 ... 3 4 [5]   Go Down
Author Topic: please add a jumper to disable auto reset  (Read 15086 times)
0 Members and 2 Guests are viewing this topic.
Lancashire, UK
Offline Offline
Edison Member
View Profile
WWW
C4 in the linked schematic is controlling the auto reset.  Without it, it won't auto reset. Or you could try tiepie's solution of putting a larger value capacitor between gnd and reset.
Logged
0
Offline Offline
Jr. Member
NAM Modular Systems industries
View Profile
Quote
For the record, the latest versions of the Duemilanove don't have the solder pads with the trace between them.  Earlier ones do, the later ones don't.  Most compatibles and knock offs have the pads as per the early original boards.
In that case ive been ripped off many a time. Why not just re-instate that trace?
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
Trust that the trace always exists or the auto-reset would not function. There just may not be an easy to see/roomy enough area to show where to cut. However once the trace is located it can either be cut or the series capacitor can be removed. I think the low ohm resistor temporarily inserted into the shield +5vdc and reset pins is the simplest way to go.
Lefty
Logged
Lancashire, UK
Offline Offline
Edison Member
View Profile
WWW
Quote
I like tiepie's absorbing the ground pulse from the auto reset capacitor into a much bigger one charged to +5v, seems more refined somehow smiley-wink
Logged
"The old Europe"
Offline Offline
Edison Member
Bootloaders suck!
View Profile
WWW
It's quite strange that this _regression_ made it to the latest boards.
Granted, a switch/jumper would be much better, but why remove it. It's not like people got confused about it or it added cost to the board.
« Last Edit: July 25, 2010, 04:26:06 pm by madworm » Logged
• Upload doesn't work? Do a loop-back test.
• There's absolutely NO excuse for not having an ISP!
• Your AVR needs a brain surgery? Use the online FUSE calculator.
My projects: RGB LED matrix, RGB LED ring, various ATtiny gadgets...
• Microsoft is not the answer. It is the question, and the answer is NO!
SF Bay Area (USA)
Online Online
Faraday Member
Strongly opinionated, but not official!
View Profile
Quote
Huh.  I dislike it when open source hardware published designs get out-of-sync with the versions that are actually shipping (or even non-open-source designs with published schematics.)  On the other hand, it's pretty tough to keep in sync (you don't want to publish a new design for every minor manufacturing change), and the Freeduino designs seem to have suffered the same fate, so I guess I'll survive...
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Thanks Lefty,
I will remove the C4 0.1uf ceramic capacitor connected to the reset tack switch.
So removing the C4 is the same as adding a switch with a resistor that is connected to a 9V source in the DTR part?
Regards
Logged
Lancashire, UK
Offline Offline
Edison Member
View Profile
WWW
Removing the C4 capacitor completley disables auto reset, not quite sure how the 9v enters into the equation.
The reset on the arduino is activated when the pin is brought LOW (0v) from its normal state held high (5v) by a 10k resistor.  What happens with the DTR is that the DTR is usually high (5v) and goes low when the serial port is initialised.  This change of state is 'transferred' via C4 to the reset pin which temporarily drops low before being brought high again by the pull up resistor and resetting the Arduino.  If C4 isn't there it doesn't happen and the arduino only resets by pressing the button. The workarounds to this autoreset revolve around keeping the reset pin High despite the best efforts of C4 to bring it low when DTR goes low.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Thanks Pluggy!
Logged
Rome
Offline Offline
God Member
Arduino rocks
View Profile
Don't know if it has already been said in previous page, anyway here it is the solution for Arduino serial controlling from Windows XP in VBA (Visual Basic for Applications):
Connect your source to Microsoft Comm Control (MSCOMM32.OCX) , then:
Dim MSComm1 As Object
Sub ArduinoOpen()
    Set MSComm1 = CreateObject("MSCOMMLib.MSComm")
    MSComm1.Settings = "9600,n,8,1"
    MSComm1.CommPort = 4
    MSComm1.InBufferCount = 0
   MSComm1.DTREnable = False
    MSComm1.PortOpen = True
      If Err Then
         MsgBox "COM" & MSComm1.CommPort & ": not opened, Sorry!"
         Exit Sub
      End If
End Sub
Sub ArduinoClose()
    MSComm1.PortOpen = False
    Set MSComm1 = Nothing
End Sub
Tested on ArduinoUno
Logged
Pages: 1 ... 3 4 [5]   Go Up
Print
Jump to:
