Author Topic: BUG: when (double) 2+2 does not equal four  (Read 634 times)
I've been playing with calculating sunrise/sunset on an arduino Diecimila.  Consider the following code fragment and the comments:
// debugging the J calculation
  double J1 = 2451545;  // ok - got 2451545
  double J2 = 0.0009;   // ok - got 0.0009
  double J3 = 2*M_PI;   // ok - got 6.283185
  double J4 = Lw/J3;    // ok - got 0.215978
  double J5 = J1 + J2;  // wrong - got 2451545.000000
  double J6 = J5 + J4;  // wrong - got 2451545.250000 - even
                        // assuming the bug is in the serial
                        // library println() function, its
                        // still wrong.
  double J7 = J6 + n;   // ok - ignoring previous errors, this
                        // gives 2455513.250000 which is correct.
I might have thought that there was a problem with a cast somewhere, but the bug occurs well after we've established the type of each variable *and* verified correct results.  Interestingly, only addition appears to be affected.  All other operations appear fine.
Left Coast, USA
Sometimes I just can't help myself.
In avr-gcc, doubles are 32-bit floats.  They are good for about seven significant decimal digits.  This has nothing to do with the Serial print function or any other library functions.
I'll look at J5:
How is J5 going to be stored in the machine?
The actual value of J1 + J2 is equal to 2451545.0009, which would require eleven significant decimal digits.
The compiler generates code that stores the 32-bit binary floating point number that is the closest that it can get to 2451545.0009.  That turns out to be 2451545.0
Bottom line: Adding a small number to a large number can result in loss of significance.
Regards,
Dave
« Last Edit: November 14, 2010, 12:15:54 pm by davekw7x » Logged
ok.  Maybe the wording should be a little clearer in the reference manual or an example given for the kinds of problems that can crop up due to the 32 bit double.
I can reduce one constant by 2451545 in the calculations and still get a usable result so maybe that's a better approach.  I'll give that a try.
Essex, UK
As well as the significant digits issue be careful with doing any calculations that rely on the accuracy of the fractional part of a float (or double) because its internal representation as a binary fraction does not map exactly to the set of decimal fractions. Many common decimals are repeating binary fractions.
Home of the Nokia QVGA TFT LCD hacks: http://andybrown.me.uk
