Loading...
Pages: [1]   Go Down
Author Topic: Arduino Serial Problems  (Read 682 times)
Cambridge,UK
Offline Offline
Newbie
If at first you don't succeed; call it version 1.0
View Profile
WWW
Hi all,
I've got some code (there's a lot of it, hence why I'm not posting straight away) that polls two analog inputs, stores the values temporarily in RAM, then serves up a serial string consisting of a S/N and the two archived values.
Now, the code works, for a few minutes, then just seems to flake out, mid-string.
I'm using the default serial rate of 9600 bps, with a FT-232 Adapter board.
I've tried the code on a variety of boards (MEGA 1280, Mini Pro 328, Demilunovae and a selection of hand-built boards), to no avail...
Changing the program cycle frequency seems to have no effect, with the code eventually halting abruptly mid-string, every time(!).
Here's the function for sending the data string...
Quote
void transmit_packet(int RH,int temp)
  xb_awake();
  xb_init();
 // Serial.print("&");
   for (int i = 0; i<6;){
   Serial.print(serial);
   i++;}
  Serial.print(",");
 // Serial.print("T=");
  Serial.print(temp);
  Serial.print(",");
  Serial.print(RH);
  Serial.println("");
  xb_sleep();
And the main program flow...
Quote
void loop()                        //MAIN PROGRAM
  get_data();                      // Poll Analog Inputs
  transmit_packet(RH, temp);       // Pass data to xBee for transmission
  delay(transmission_delay);
  check_serial_num();
  loop();                          // Loop Around
I haven't included the get_data function, as I don't think it's causing any problems, but its pretty simple, read A0 and A1, store to variables RH and temp.
The code seems to be breaking mid-flow of transmit_packet, and it's left me at a loss...  :-/
Has anyone experienced anything similar when going heavy on the Serial.print function?
Thanks all,
Tom
« Last Edit: October 05, 2010, 07:43:47 am by tomfleet » Logged
0
Offline Offline
Faraday Member
ruggedcircuits.com
View Profile
WWW
Here's your problem:
Code:
  check_serial_num();
  loop();                          // Loop Around [glow]<---- NOOOOO!!!!!!![/glow]
You should not have loop() calling itself as you will eventually smash the available stack space on the processor. loop() is called in a loop anyways...there is no need for you to keep calling it.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, light sensor, potentiometers, pushbuttons
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi there.
I have a similar problem ith a NANO-board. That is that when I run a program that sends out strings (regular intervals ~ 1sec) the program seems to halt after a while when I don't read the data.
The program flow is monitored by an activity-led (13) when the data is sent. When I plug the USB back in or read data the program resets (values are re-initialized!)
The problem is that the board is intended for stand-alone use and sometimes can be monitored for correct functioning.
Anyone an idea?
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Quote
Anyone an idea?
Create a new topic in the Software section where your problem can be discussed.
Post your entire Sketch using code tags.
Include a detailed description of what is happening and what you expect to happen.
Logged
Pages: [1]   Go Up
Print
Jump to:
