Loading...
Pages: [1]   Go Down
Author Topic: serial print from memory  (Read 658 times)
Michigan
Offline Offline
Newbie
IR Combat
View Profile
WWW
Is it possible to implement a new simple function to print to an LCD from memory (not RAM) without having to use the complicated progmem function?  like a simple
memory.print("XXXX");
I have a library someone else wrote that does that and it saves tons of RAM withough having to use progmem directly.
Logged
IR Combat laser tag developer/inventor
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
You said have the library -what's the problem?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Portugal
Offline Offline
God Member
View Profile
The only wait do do that is using PROGMEM in the declaration and then pgm_read_byte_near, so its pretty simple to use....
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
I recognize all of those words, but I don't think that I've ever seen them used in that order before. That particular order did not convey much to me.
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
I don't know if it will work with an LCD but the Flash Library works with Serial and makes embedding string constants very simple...
http://arduiniana.org/libraries/flash/
Logged
Pages: [1]   Go Up
Print
Jump to:
