Topic: serial print from memory (Read 1 time) previous topic - next topic
zachtos
Is it possible to implement a new simple function to print to an LCD from memory (not RAM) without having to use the complicated progmem function?  like a simple
memory.print("XXXX");
I have a library someone else wrote that does that and it saves tons of RAM withough having to use progmem directly.
IR Combat laser tag developer/inventor
AWOL
You said have the library -what's the problem?
Senso
The only wait do do that is using PROGMEM in the declaration and then pgm_read_byte_near, so its pretty simple to use....
PaulS
I recognize all of those words, but I don't think that I've ever seen them used in that order before. That particular order did not convey much to me.
Coding Badly
I don't know if it will work with an LCD but the Flash Library works with Serial and makes embedding string constants very simple...
http://arduiniana.org/libraries/flash/
