0
Offline
Newbie
Arduino rocks
« Reply #2 on: November 13, 2010, 10:48:11 pm » |
Thanks for the prompt response! The rate is 115200. I am using the USB port of a Dell Optiplex 755 which is the same hardware I was using previously with the Duemilanove. Here is the source code:
#include <Spi.h>
// Melexis definitions #define MLX_START_BIT 0x80 #define MLX_RESET_PIN 8 #define MLX_ERRB_PIN 9
#define SER_READ_DELAY 10 // in microseconds
#define GAUGE_LOOKUP { 0x00, 0x10, 0x30, 0x40, 0x60, 0x50 }
#define OP_ZERO_GAUGE 0x0 #define OP_R_U_THERE 0x1 #define OP_SET_GAUGE 0x2 #define OP_DEBUG 0x7
#define ACK_CODE_BIT 0x80 #define RC_OK 0X00 #define RC_ERR_UOP 0x01 // Unknown op code received #define RC_ERR_MDATA 0x02 // Missing expected data packets #define RC_ERR_OP_WDATA 0x03 // Wrong number of data packets for op #define RC_ERR_INV_METR 0x04 // Invalid meter or gauge specified
const byte gauge_lookup_tbl[6] = GAUGE_LOOKUP;
int data = 2; int clock = 3; int latch = 4; int debug = 0;
void setup() { int var = 0; byte spi_config = 0; Serial.begin(115200); pinMode(MLX_RESET_PIN, OUTPUT); pinMode(MLX_ERRB_PIN, INPUT); pinMode(data, OUTPUT); pinMode(clock, OUTPUT); pinMode(latch, OUTPUT);
var = digitalRead(MLX_ERRB_PIN); digitalWrite(MLX_RESET_PIN, HIGH); delayMicroseconds(8000); SPSR &= B11111110; // 0th bit is SPIX2 spi_config |= (1 << SPE) | (1 << MSTR) | (1 << SPR0); Spi.mode(spi_config); }
void loop() { byte cmd = 0, dataPackets = 0, data[3]; int rc = RC_OK, val = 0, gaugeNum = 0; data[0] = 0; data[1] = 0; data[2] = 0; if (Serial.available()) { cmd = Serial.read(); updateLEDs(cmd); if (cmd == -1) return; // If nothing read no need to continue dataPackets = (cmd >> 3) & 0x3; switch(cmd >> 5) { case OP_SET_GAUGE: gaugeNum = cmd & 0x3; if (dataPackets != 2) rc = RC_ERR_OP_WDATA; else if (gaugeNum < 1 || gaugeNum > 5) rc = RC_ERR_INV_METR; else { rc = readDataBytes(data, dataPackets); if (rc == RC_OK) { val = data[0] << 8 | data[1]; setGauge(gaugeNum, val); } } // TODO: Check pin ERRB on melexis to detect errors and return them //sendAck(RC_OK); break; case OP_ZERO_GAUGE: gaugeNum = cmd & 0x3; if (dataPackets != 0) rc = RC_ERR_OP_WDATA; else if (gaugeNum < 1 || gaugeNum > 5) rc = RC_ERR_INV_METR; else initMainLogometers(); break; case OP_R_U_THERE: if (dataPackets != 0) rc = RC_ERR_OP_WDATA; break; case OP_DEBUG: debug = 1; if (dataPackets != 0) rc = RC_ERR_OP_WDATA; break; default: rc = RC_ERR_UOP; break; } sendAck(rc); }
int readDataBytes(byte *data, int count) { int i = 0, readCount = 0; byte cmd; for (i = 0; i < count; i++) { do { data = Serial.read(); readCount++; if (data == -1) delayMicroseconds(SER_READ_DELAY); else break; } while (readCount < 10); if (data == -1) return RC_ERR_MDATA; } return RC_OK; }
void sendAck(int errCode) { byte cmd = 0; cmd = ACK_CODE_BIT | (errCode & 0x7f); Serial.write(cmd); }
void setGauge(int gauge, int val) { int quad = 0, offset = 0; quad = 0x3 & (3 + (val/512)); offset = val % 512; sendByComp(gauge, quad, offset); }
void initMainLogometers () { int i = 0, calDelay = 1000, quad = 0, offset = 0; for (i = 200; i < 1500; i += 4) { delayMicroseconds(calDelay); quad = 0x3 & (3 + (i/512)); offset = i % 512; sendByComp(1, quad, offset); sendByComp(2, quad, offset); } for (i = 1500; i >= 200; i -= 4) { delayMicroseconds(calDelay); quad = 0x3 & (3 + (i/512)); offset = i % 512; sendByComp(1, quad, offset); sendByComp(2, quad, offset); } }
void sweepMainLogometers () { int i = 0, j = 0, calDelay = 2000; for (j = 3; j < 7; j++) { for (i = 0; i < 512; i++) { delayMicroseconds(calDelay); sendByComp(1, 0x3&j, i); sendByComp(2, 0x3&j, i); } } for (j = 6; j >= 3; j--) { for (i = 511; i >= 0; i--) { delayMicroseconds(calDelay); sendByComp(1, 0x3&j, i); sendByComp(2, 0x3&j, i); } } }
void sendByComp(int gauge, int quad, int val) { byte b1; byte b2; if (val < 0 || val > 511) { pDataValidationError("Error valid quadrant table lookups are 0 to 511, received ", val); return; } if (quad < 0 || quad > 3) { pDataValidationError("Error valid quadrants are 0 to 3, received ", quad); return; } b1 = MLX_START_BIT | gauge_lookup_tbl[gauge] | (val >> 5); b2 = 0x00 | val << 3 | quad; digitalWrite(SS_PIN, HIGH); Spi.transfer(b1); Spi.transfer(b2); digitalWrite(SS_PIN, LOW); }
void pDataValidationError(char *msg, int val) { Serial.print(msg); Serial.print(val); Serial.println(); }
void updateLEDs(int value){ digitalWrite(latch, LOW); //Pulls the chips latch low shiftOut(data, clock, MSBFIRST, value); //Shifts out the 8 bits to the shift register digitalWrite(latch, HIGH); //Pulls the latch high displaying the data }
