Topic: To have reference designs in gEDA & PCB files (Read 6229 times) previous topic - next topic
Pál Csányi
Dec 18, 2010, 02:41 pm Last Edit: Dec 18, 2010, 02:42 pm by csanyi_pal Reason: 1
Hello,
I wish to have reference designs not only in EAGLE files but also in gEDA gschem and PCB files too.
gEDA: http://www.gpleda.org/index.html
Best, Pali
cr0sh
Wish all you want, but I doubt it will happen unless you do it yourself.
Search around on the forum and on google; I seem to recall that someone was working on getting the schematic (to one of the Arduinos - maybe the UNO) converted. As for the PCB...
jabber
#2
Dec 30, 2010, 12:41 am Last Edit: Dec 30, 2010, 12:44 am by jabber Reason: 1
Here is something I have been using myself. The gschem symbols are not drawn to the geda standard sizes which are way too big for me, but the component may still be of some use to you.
http://homepage.ntlworld.com/stevecole1/downloads/arduino.tgz
jabber
Just noticed the tgz file is not complete. I will post it again later on.
Pál Csányi
Best, Pali
jabber
Now added the board & schematic to the file. Use at your own risk, this is the third version of the board and at the moment it is untested, although the first two versions are still going strong after almost a year.
cr0sh
Darn - I installed PCB on my system (from the repository), and your version was newer than mine, so it won't load the board; gschem had no problem with the schematic, though.
I probably just need to upgrade my system (on Ubuntu 9.10) - I just hate doing it, because it invariably breaks things, then I sit there for a week trying make all my crap work again...
But thanks anyhow for making this available - I'm glad to be proved wrong!
:D
jabber
#7
Jan 01, 2011, 08:07 am Last Edit: Jan 01, 2011, 08:11 am by jabber Reason: 1
Try hacking the date FileVersion in the pcb file (hooray for text based file formats) . It might work
cr0sh
Hey - that worked great!
:D
Pál Csányi
My system is Debian GNU/Linux Squeeze and have had installed PCB from Debian package repository too, but I delete this installation. I downloaded then PCB from http://sourceforge.net/projects/pcb/files/pcb/pcb-20100929/pcb-20100929.tar.gz/download and installed it so it works.  :D
Best, Pali
jabber
Just had a look at this in a standard installation of pcb and the layer colors are, erm.. interesting. I had forgotten how much my installation was modified.
cr0sh
Are these "mods" something that can be done by changing some config options or such, or are they something that need to be compiled in? I don't know anything about pcb (and very little about gschem), but both are programs I ultimately want to learn...
jabber
I am working from middle aged memory  :).
If you start the pcb program & go to   file - preferences - colors then all the layer settings colors can be changed from there. (I'm being very American here, I'm getting lots of red squiggles underneath the word [glow]colours[/glow]).
These settings can be saved in a file in  the .pcb hidden directory in the home folder and I *think* they are loaded automatically the next time the program starts.
If I use a ground plane then I find it convenient to put it on it's own layer & set it to a slightly different color to the traces on the same side of the board as can be seen in the screenshot posted above.
To do this, BEFORE I start laying out a board design, I need to go to the menu Settings - New lines,arcs clear polygons  and then, any ground plane will automatically keep away from traces on the same side of the board, or if I need to lay a new trace, it will push the ground plane out of the way.
If this is done then I can go into  file - preferences - layers - groups and set the trace layer & the ground layer to the same group and they will be treated as one entity. The two layers can be displayed or hidden together by either of the layer buttons.
It is sometimes convenient to hide the ground plane temporarily,  it just needs to have it's group setting changed & it can be hidden without affecting the traces on the same side of the board.
The only other thing I did was to hack the pcb code & gnetlist scripts to allow 8 trace styles(widths) instead of the standard 4 but that is a whole different ball game for another day.
cr0sh
I'd be interested in seeing this, though I likely wouldn't use it anytime soon; hacking on code is what I do for a living (been coding since I was 10 years old; professionally for the past 20 years).
jabber
AAAAGH! I just hit reset instead of post on a long reply.
