Topic: Arduino with networking like the netduino plus (Read 10383 times) previous topic - next topic
hanpa
Jan 04, 2011, 08:13 pm Last Edit: Jan 04, 2011, 08:16 pm by hanpa Reason: 1
I have may ideas for projects that require ethernet connection, it's too awkward and expensive to use an ethernet shield.
The netduino plus has ethernet but I'm not sure that I want to use .NET.
Is an Arduino version planned with ethernet on board?
Can the netduino plus be programmed with the Arduino programming environment including the ethernet hardware?
Edit: Should have posted this in Development, sorry
robtillaart
#1
Jan 04, 2011, 10:34 pm Last Edit: Jan 04, 2011, 10:35 pm by robtillaart Reason: 1
Quote
You can use a serial connection to a PC that has an internet connection and use the PC as bridge. Almost all prog languanges on a PC support serial ports so ...
Quote
FEZ is also a .NET based solution, that is (more or less) hardware compatible with Arduino shields. www.tinyclr.com
Quote
There are arduino compatible boards with wifi - http://asynclabs.com/store?page=shop.product_details&flypage=flypage.tpl&product_id=23&category_id=11&vmcchk=1 ??
Quote
Not afaik, it is a completely different software platform that has similar hardware pin layout
Quote
Apologies accepted :)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
arian
This is exactly why i develop my custom arduino like pcb :D It contains enc28j60 chip, digital thermometer and configuration reset button on unused (by arduino) analog pins.
However, i can't tell you when it will be available ;)
hanpa
Quote
I know but I want to have separate boards in different rooms in my house, with ethernet connection to get/put data directly or through my linux server that is always on and can process data more intelligently when required. Don't want PCs everywhere...
An Arduino with LAN or WLAN on board is the ideal solution for me.
tfdk
I believe the Arduino team is working on the perfect device for you:
There is a blog post with a picture of an early prototype on the Arduino blog titled: "Arduino Ethernet And The Gym"
At the Arduino Uno event at NY Maker Faire, they talked a little about it and said that it could be powered over ethernet (real POE) and also be updated (programmed) over ethernet.
I don't have any details on when it will be available, but I sure will get some when they are.
/Thomas
tfdk
Here is a link to the post: http://arduino.cc/blog/2010/11/15/arduino-ethernet-at-the-gym/
/Thomas
marklar
Quote
Cost:
http://www.dfrobot.com/index.php?route=product/product&keyword=ethernet&category_id=0&product_id=52
$34
http://www.dfrobot.com/index.php?route=product/product&path=35_38&product_id=49
$24
Total: $58 plus pretty expensive shipping
... as compared to ...
http://www.makershed.com/ProductDetails.asp?ProductCode=MKND02
$59.95
Pretty close price.
I have a netduino and a fez panda and have developed in .net quite a bit outside the boards.  I still use arduino for everything as I have yet to be able to accomplish the same level of implementation with the .net systems as I do with arduino.  That said - port write speed is very slow without "going native", which was a show stopper for me.  If you don't need fast port write speed and like .net - it may work for you.
