Author Topic: Arduino with networking like the netduino plus  (Read 3247 times)
I have may ideas for projects that require ethernet connection, it's too awkward and expensive to use an ethernet shield.
The netduino plus has ethernet but I'm not sure that I want to use .NET.
Is an Arduino version planned with ethernet on board?
Can the netduino plus be programmed with the Arduino programming environment including the ethernet hardware?
Edit: Should have posted this in Development, sorry
« Last Edit: January 04, 2011, 02:16:05 pm by hanpa » Logged
Netherlands
You can use a serial connection to a PC that has an internet connection and use the PC as bridge. Almost all prog languanges on a PC support serial ports so ...
FEZ is also a .NET based solution, that is (more or less) hardware compatible with Arduino shields. www.tinyclr.com
There are arduino compatible boards with wifi - http://asynclabs.com/store?page=shop.product_details&flypage=flypage.tpl&product_id=23&category_id=11&vmcchk=1 ??
Not afaik, it is a completely different software platform that has similar hardware pin layout
Apologies accepted smiley
« Last Edit: January 04, 2011, 04:35:18 pm by robtillaart » Logged
Rob Tillaart
This is exactly why i develop my custom arduino like pcb smiley-grin It contains enc28j60 chip, digital thermometer and configuration reset button on unused (by arduino) analog pins.
However, i can't tell you when it will be available smiley-wink
I know but I want to have separate boards in different rooms in my house, with ethernet connection to get/put data directly or through my linux server that is always on and can process data more intelligently when required. Don't want PCs everywhere...
An Arduino with LAN or WLAN on board is the ideal solution for me.
I believe the Arduino team is working on the perfect device for you:
There is a blog post with a picture of an early prototype on the Arduino blog titled: "Arduino Ethernet And The Gym"
At the Arduino Uno event at NY Maker Faire, they talked a little about it and said that it could be powered over ethernet (real POE) and also be updated (programmed) over ethernet.
I don't have any details on when it will be available, but I sure will get some when they are.
/Thomas
Here is a link to the post: http://arduino.cc/blog/2010/11/15/arduino-ethernet-at-the-gym/
/Thomas
Florida
hookedup!
Cost:
http://www.dfrobot.com/index.php?route=product/product&keyword=ethernet&category_id=0&product_id=52
$34
http://www.dfrobot.com/index.php?route=product/product&path=35_38&product_id=49
$24
Total: $58 plus pretty expensive shipping
... as compared to ...
http://www.makershed.com/ProductDetails.asp?ProductCode=MKND02
$59.95
Pretty close price.
I have a netduino and a fez panda and have developed in .net quite a bit outside the boards.  I still use arduino for everything as I have yet to be able to accomplish the same level of implementation with the .net systems as I do with arduino.  That said - port write speed is very slow without "going native", which was a show stopper for me.  If you don't need fast port write speed and like .net - it may work for you.
