Loading...
Pages: [1] 2   Go Down
Author Topic: Rant about manufacturing quality  (Read 3669 times)
0
Offline Offline
Jr. Member
Uno momento
View Profile
Now I really come to look at my Arduino Uno board in detail, it looks like some ham-fisted slob has had at it with an arc welder and ran out of solder half way through before shipping it anyway...
Pin 0 was not even soldered at all!  And I have no idea how those blobs of solder ended up on those vias like that, it even bridges two vias together in a nasty way.
What should I do?  I've already had to solder on one of the ICSP pins in place because it was sliding in and out of the board and would have fallen out completely if I hadn't.  That was some time ago now though, I hadn't even noticed these other faults.
That said, the arduino doesn't seem to complain of anything else, it all seems to work properly.
I'm going to solder the RX pin myself, because it should clearly be connected to the pin header block, but what about the blobs?  Should I remove them or are they supposed to bridge like that?
I accept that sometimes humans have to fix up a product that hasn't gone through fabrication very nicely but to leave the job half done like this AND expect me to pay full price for it is a bit cheeky.
I still love the product though and I will no doubt buy more in the future but I'm still a bit ticked off about it.
Has anyone else had these problems?
Logged
'round the world...
Offline Offline
Edison Member
View Profile
WWW
I believe these are "wave welded", there are no humans involved at all...
And machines do fail.
About the RX pin, you can solder it... about the blobs, knowing where exactly they are would help far more than a small pic of them.
Where are they located?
Logged
Eu não sou o teu criado. Se respondo no fórum é para ajudar todos mediante a minha disponibilidade e disposição. Responder por mensagem pessoal iria contra o propósito do fórum e por isso evito-o.
Se realmente pretendes que eu te ajude por mensagem pessoal, então podemos chegar a um acordo e contrato onde me pagas pela ajuda que eu fornecer e poderás então definir os termos de confidencialidade do meu serviço. De forma contrária toda e qualquer ajuda que eu der tem de ser visível a todos os participantes do fórum (será boa ideia, veres o significado da palavra fórum).
Nota também que eu não me responsabilizo por parvoíces escritas neste espaço pelo que se vais seguir algo dito por mim, entende que o farás por tua conta e risco.
Dito isto, mensagens pessoais só se forem pessoais, ou seja, se já interagimos de alguma forma no passado ou se me pretendes convidar para uma churrascada com cerveja (paga por ti, obviamente).
Lancashire, UK
Offline Offline
Edison Member
View Profile
WWW
There were one or two whinges about quality when the Uno first came out, its been pretty quiet since then.   My Uno, whilst not as good as a couple of old Duemilanoves I have is OK, my gripes are with the bootloader, having to update the 8U2 firmware (propably a non issue by now) and cheapskate resonator instead of a crystal.
Logged
0
Offline Offline
Jr. Member
Uno momento
View Profile
bubulindo, sorry they are on the underside, immediately north of the black 2.1mm power jack socket.  To my uneducated eye, they don't look like they should be there, but how to remove them safely without accidentally damaging the via or otherwise ruining the board?  Perhaps I should just leave them alone.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
Hard to say without a picture to judge. If you do want to remove a little solder, I've had luck using solder wick brade, just lay the end of the brade flat as possible on the blog and apply the iron to the brade, it will suck-up a lot of the excess solder.
http://www.sparkfun.com/products/9327
Lefty
« Last Edit: January 15, 2011, 02:10:13 pm by retrolefty » Logged
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
I have used that brand, them and MG chemicals the stupid case melts as your using it, though its stuck out quite far
I am becoming a bit of a braid snob, as I use it like toilet paper, and though its nearly 2x the cost I am actually partial to radio shack stuff, it has a courser braid which seems to suck up more per spot, and it has some pretty aggressive flux
Though liquid flux on whatever your about to desolder helps a TON! the radio shack stuff can suck up a normal sized bead on perfboard as is super quick, this stuff and the MG stuff is like wiping up a pile of vomit with a Kleenex without extra flux and fiddling around (maybe becuase its full of crappy plastic before you even get to use it, where as the radio shack spool can take small hits directly from an iron without melting)
wick snob out  ;D
Logged
0
Offline Offline
Jr. Member
Uno momento
View Profile
Quote
 There is a picture, in the first post.
« Last Edit: January 16, 2011, 06:56:11 am by wossname » Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Still shuddering at the thought of using desolder braid as toilet paper.
That's got to hurt.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
0
Offline Offline
Jr. Member
Uno momento
View Profile
A solder pump would get clogged up I suppose smiley-grin
Logged
Offline Offline
Brattain Member
View Profile
Quote
That's got to hurt.
Only if you apply the iron?
Lefty
Logged
Lancashire, UK
Offline Offline
Edison Member
View Profile
WWW
Quote
Now my eyes are watering.......
Logged
'round the world...
Offline Offline
Edison Member
View Profile
WWW
Quote
There is a comment on the second post about a picture being needed.
Logged
Offline Offline
Brattain Member
View Profile
My error was I just didn't scroll to the right of the picture cause I didn't notice the scroll bar. Duh!
Lefty
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Quote
Too much smoke from the flux  ;D
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
0
Offline Offline
Jr. Member
Uno momento
View Profile
I'm sure there was a topic in here somewhere.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
