Loading...
Pages: [1]   Go Down
Author Topic: Found this on Digg.com  (Read 615 times)
Orlando, FL
Offline Offline
Full Member
View Profile
WWW
How hard would it be to modify the arudino board to control 32 servos independantly?  This company is doind it with the same chip used in the Arduino board.
http://www.botmag.com/articles/brat_photoessay.shtml
Logged
0
Offline Offline
Jr. Member
View Profile
I've seen this servo controller before. It's available individually for pretty cheap:
http://www.lynxmotion.com/Product.aspx?productID=395&CategoryID=52
Regarding your question: dunno how to do this with the arduino. But the firmware for this thing is open source, so you can have a look at how they did it.  smiley
http://www.lynxmotion.com/images/html/proj078.htm
Description of SSC-32 Operation:
http://www.lynxmotion.com/images/html/proj078a.htm
« Last Edit: October 24, 2006, 03:45:22 am by brainfart » Logged
Forum Administrator
Offline Offline
Newbie
View Profile
i think if you try to build the same in arduino you might end up spending more money:)
just buy theirs if you are in the US, the price is honest
if you aren't then it's more expensive... the firmware is oss and the circuit provided
it's a bunch of shift registers 74hc595 connected to an atmega8
if you port it be aware they use a 14MHz quartz versus arduino uses a 16MHz quartz
massimo
Logged
Pages: [1]   Go Up
Print
Jump to:
