Loading...
Pages: [1]   Go Down
Author Topic: Arduino Mini schematic incorrect?  (Read 680 times)
Chicago IL USA
Offline Offline
Jr. Member
int myMind = 0;
View Profile
Perhaps I'm just imagining things, but I was looking at the Mini schematics last night and noticed that the chip is listed as an ATMEGA8 when it should be ATMEGA168 no? Also, the pictures of the board show all of 4 components total while the schematic shows 10. Just wondering regarding this because it's a little more unusual to have smt parts on both sides of the board.
I am working on a purpose specific Arduino board, so I want to make sure I can avoid including any unnecessary parts.
Logged
there are 10 types of people in this world, those who can read binary and those who can't.
Forum Administrator
Offline Offline
Newbie
View Profile
hi
a few notes
Atmega8 and 168 are pin compatible so it's all the same
the schematic is the bare minimum already but it's correct (it's the one used for production)
there are parts on the bottom side. it's quite common when you dont have that much space
making a custom smd board requires quite a bit of experience, wouldn't it be simpler to get a mini put your stuff on another board connected to it...
massimo
Logged
Chicago IL USA
Offline Offline
Jr. Member
int myMind = 0;
View Profile
I'll be picking up a mini for dev work, but in the end I want a all in one board (it'll have more components to suit it's use).
I don't have any problem designing smt boards, but the software I use won't allow smt parts on the back of the board smiley-sad
thanks for the info though
Logged
Forum Administrator
Offline Offline
Newbie
View Profile
wow even eagle free version lets you do that
what software are u using?
BTW when you have made your board you should document it on the playground
Logged
Chicago IL USA
Offline Offline
Jr. Member
int myMind = 0;
View Profile
I'm using Osmand... I want to use Eagle, but I'm on a mac and I seem to have issues with the installer.
:edit: it won't let me install X11, telling me I already have a newer version installed (which I don't) so I can do anyting with it >smiley-sad
« Last Edit: December 08, 2006, 02:22:40 pm by greyskale » Logged
Daniel
Guest
try to get Eagle going, it is about twenty times better than Osmond. You need X11 to run it on a mac; I've installed Eagle on four macs with no problem...
« Last Edit: December 08, 2006, 02:21:26 pm by Daniel » Logged
Chicago IL USA
Offline Offline
Jr. Member
int myMind = 0;
View Profile
see above edit ^
Logged
Chicago IL USA
Offline Offline
Jr. Member
int myMind = 0;
View Profile
Quote
do you have any advice regarding installation? when I try to install X11 I get the message: "You can not install X11 on this volume. Newer Software already exists on your computer"
This is untrue... I don't have X11 on my machine... hense the need for installation smiley-wink
Logged
Daniel
Guest
It could be a lot of different things causing that, and I'm no X11 expert... did you try trashing any preference file(s) for X11?
a quick google search comes up with this:
http://lists.apple.com/archives/x11-users/2006/Oct/msg00020.html
D
« Last Edit: December 08, 2006, 08:40:16 pm by Daniel » Logged
Chicago IL USA
Offline Offline
Jr. Member
int myMind = 0;
View Profile
I think I know the issue now... I've been trying to install the version on apples site... this is an older version for 10.3. I'll try to use the installer on my 10.4 disks when I get home tonight and see if that works.
Logged
Montréal, Qc
Offline Offline
Full Member
Practice safe hex!
View Profile
You might also want to have a look at the installation receipt from X11 in /Library/Receipts/.
DesInstaller is a nice little tool to deal with these (it also removes the associated files).
Also keep in mind that although you can start eagle from the Terminal.app (not xTerm) you need to have X11 started already for this to work!
If you still have problems, you could try installating Eagle from a package distribution (iirc Darwinports has it listed).
Hope this helps!
Logged
"Pilots believe in a clean living... they never drink wisky from a dirty glass."
Pages: [1]   Go Up
Print
Jump to:
