Topic: Arduino scintillation counter Radiation (Read 3939 times) previous topic - next topic
door144
I am trying to build this Instructable (http://www.instructables.com/id/Real-time-Radiation-Detector-Scintillino-test/) to no avail. I have built the whole thing but am still getting no reading. I have spend days working on it I don't know what I am doing wrong. I have went back a replaced every component tried to contact the individual who created this masterpiece but no luck. Any help guys  =(
door144
jremington
You need access to an oscilloscope to troubleshoot this circuit. Look for pulses coming out of the photomultiplier and go from there.
door144
Ok I can get one by any chance do you know where I would attach the oscilloscope to in the circuit. What am I looking for in the oscilloscope I'm sorry I'm new to this. Thank you for the help
jremington
#4
Apr 10, 2014, 04:32 am Last Edit: Apr 10, 2014, 04:34 am by jremington Reason: 1
Ask the person from whom you borrow the oscilloscope to help. These instruments are not designed so that a beginner can figure out how to use them, without instruction.
door144
That can be done thank you. I have another question if anyone can take a look at the electrical diagram I think I keep shorting the DC DC step up. I will upload a photo here too.
Grumpy_Mike
The electrical diagram is fine. However you might be misinterpreting it. What makes you think it is shorting out?
Have you measured the voltage output of the converter with a multimeter? That will tell you.
door144
Here is the electrical diagram from the instructable. I think the SiPM is in backwards too. I'm not great at reading this.
jremington
Quote
If you think you put it in backwards, try the other way. It won't work in the incorrect orientation. In an Instructable, you get what you pay for. This one is an example.
door144
Yes I think the SiPM is backwards. Does anyone know how to tweak it once I have the oscilloscope?
Grumpy_Mike
Quote
Tweek it for what?
door144
Just what am I looking for once I can test this with a oscilloscope? Should I vary the power going to the SiPM or chance resistors?
jremington
Turn it around first. It may work after that.
door144
Its turned around but im still reading all 0's from the serial monitor  :~
Grumpy_Mike
Quote
Pulses into the amplifier and pulses out of it.
