Hi Peter,
yes i to change is the numbers in those attachInterrupt lines.I had also to change in/out pin.
However, I have the same problem as before. At a higher speed encoder stepper motor slow work.
If encoder slowly move work ok. There is no error in the Arduino mini but in the program.
Can you help me how can I fix the error that signals from encoder fast read and sent to the stepper motor.
This is new code
#define encoder_a 22 //keep this on and interrupt pin
#define encoder_b 23 //keep this on and interrupt pin
#define motor_step 53 //can be any pin
#define motor_direction 52 //can be any pin
volatile long motor_position, encoder;
void setup () {
//set up the various outputs
pinMode(motor_step, OUTPUT);
pinMode(motor_direction, OUTPUT);
// then the encoder inputs
pinMode(encoder_a, INPUT);
pinMode(encoder_b, INPUT);
// enable pullup as we are using an open collector encoder
digitalWrite(encoder_a, HIGH);
digitalWrite(encoder_b, HIGH);
// encoder pin on interrupt 0 (pin 2)
attachInterrupt(22, encoderPinChangeA, CHANGE);
// encoder pin on interrupt 1 (pin 3)
attachInterrupt(23, encoderPinChangeB, CHANGE);
encoder = 0; //reseet the encoder position to 0
//do stuff dependent on encoder position here
//such as move a stepper motor to match encoder position
//if you want to make it 1:1 ensure the encoder res matches the motor res by dividing/multiplying
if (encoder > 0) {
digitalWrite(motor_direction, HIGH);// move stepper in reverse
digitalWrite(motor_step, HIGH);
digitalWrite(motor_step, LOW);
delayMicroseconds(600); //_delay_us(200); //modify to alter speed
motor_position++;
encoder = 0; //encoder--;
else if (encoder < 0) {
digitalWrite (motor_direction, LOW); //move stepper forward
digitalWrite (motor_step, HIGH);
digitalWrite (motor_step, LOW);
motor_position--;
encoder = 0; //encoder++;
void encoderPinChangeA() {
if (digitalRead(encoder_a)==digitalRead(encoder_b)) {
encoder--;
else{
encoder++;
void encoderPinChangeB() {
if (digitalRead(encoder_a) != digitalRead(encoder_b)) {
encoder--;
else {
encoder++;
