Topic: How to lower power output on laser diode? (Read 2458 times) previous topic - next topic
laujm
I am looking to see if it is possible to lower the power output of a laser diode from 25 mw to 10mw. If yes, how and how would this method also differ from just adding the diode to a circuit with resistors?
johnwasser
I think the laser diode package usually includes a photodiode that measures the light output so the control circuitry can adjust current to the desired output. Perhaps you should specify which laser diode you are using and what driver circuit you are using.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
laujm
I am using this particular model from thor labs: http://www.thorlabs.us/thorproduct.cfm?partnumber=QL7816S-B-L
retrolefty
Note that seems to be just a raw laser diode with feed back sensor, so cannot be used without a compatible feedback constant current driver/controller circuit, and as such you could design it to run at any power up to it's maximum limit.
laujm
So, I would need to build my own driver in this particular case?
retrolefty
Yes
johnwasser
