Topic: Problema con libreria de Smartgpu2 (Read 844 times) previous topic - next topic
Vampiresheryl
Apr 18, 2014, 06:02 am Last Edit: Apr 18, 2014, 09:34 am by leo72 Reason: 1
Utilizo Arduino uno, sistema operativo Mac os y tengo problema con los ejemplos de la Smartgpu2 el programa es:
Code: [Select]
#include <SMARTGPU2.h>     //include the SMARTGPU2 library!
SMARTGPU2 lcd;             //create our object called LCD
void setup() { //initial setup
 //Those two functions must always be called for SMARTGPU2 support
 lcd.init();  //configure the serial and pinout of arduino board for SMARTGPU2 support
 lcd.start(); //initialize the SMARTGPU2 processor
void loop() { //main loop draw random colour, size and fill Arcs
   POINT point;
   RADIUS radiusx, radiusy;
   COLOUR colour;
   FILLGEOM fill;
   unsigned int quadrant;
   lcd.baudChange(BAUD6);           //for fast drawing we need a big baudRate
   while(1){//forever
     randomSeed(random(0,65536));   //set different seeds to obtain a good random number
     point.x=random(0,LCD_WIDTH);   //get a random number 0-319
     point.y=random(0,LCD_HEIGHT);  //get a random number 0-239
     radiusx=random(5,101);         //get a random number 5-100
     radiusy=random(5,101);         //get a random number 5-100
     quadrant=random(1,5);          //get a random number 1-4
     colour=random(0,65536);        //get a random number 0-65535
     fill=(FILLGEOM)random(0,2);    //get a random number 0-1
     //draw the Arc
     if(lcd.drawArc(point.x, point.y, radiusx, radiusy, (ARCQUADRANT)quadrant, colour, fill) != 'O'){  //draw an Arc
       while(1);                    //loop forever if different than 'O'--OK
y los problemas son casi similares en todos los ejemplos:
Code: [Select]
Arcs:22: error: 'SMARTGPU2' does not name a type
Arcs.ino: In function 'void setup()':
Arcs:28: error: 'lcd' was not declared in this scope
Arcs.ino: In function 'void loop()':
Arcs:37: error: 'POINT' was not declared in this scope
Arcs:37: error: expected `;' before 'point'
Arcs:38: error: 'RADIUS' was not declared in this scope
Arcs:38: error: expected `;' before 'radiusx'
Arcs:39: error: 'COLOUR' was not declared in this scope
Arcs:39: error: expected `;' before 'colour'
Arcs:40: error: 'FILLGEOM' was not declared in this scope
Arcs:40: error: expected `;' before 'fill'
Arcs:43: error: 'lcd' was not declared in this scope
Arcs:43: error: 'BAUD6' was not declared in this scope
Arcs:47: error: 'point' was not declared in this scope
Arcs:47: error: 'LCD_WIDTH' was not declared in this scope
Arcs:48: error: 'LCD_HEIGHT' was not declared in this scope
Arcs:49: error: 'radiusx' was not declared in this scope
Arcs:50: error: 'radiusy' was not declared in this scope
Arcs:52: error: 'colour' was not declared in this scope
Arcs:53: error: 'fill' was not declared in this scope
Arcs:53: error: expected `;' before 'random'
Arcs:56: error: 'ARCQUADRANT' was not declared in this scope
noter
Tiene toda la pinta de que no has colocado la librería en el lugar correcto. El archivo SMARTGPU2.h debería estar en la carpeta Arduino/libraries/SMARTGPU2/SMARTGPU2.h. Revisa no hayas creado alguna subcarpeta de más al descomprimir la librería.
Saludos.
Vampiresheryl
noter, muchas gracias tenias razón la mayoría de los errores se han solucionado pero aun me marca como error:
In file included from Arcs.ino:20:
/Applications/Arduino 4.app/Contents/Resources/Java/libraries/SMARTGPU2/SMARTGPU2.h:69:2: error: #error "No smartGPU2 LCDXXXxXXX board defined in smartGPU2.h file"
Disculpa mi ignorancia.
noter
Pues viene a decir que no has definido qué dispositivo estás utilizando.
Creo que tienes que editar SMARTGPU2.h (usa un editor de texto) y descomentar la línea que corresponde a tu modelo.
Vampiresheryl
Gracias noter, ya todo esta en orden, te estoy muy agradecida.
noter
Bien está lo que bien acaba. Me alegro de haberte sido de ayuda.
Sería conveniente que cambiaras el asunto del post, precediéndolo de [SOLUCIONADO].
Saludos.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
