Topic: Clearing serial buffer solved (Read 135297 times) previous topic - next topic
Delta_G
#15
Aug 11, 2017, 01:06 am Last Edit: Aug 11, 2017, 01:07 am by Delta_G
Im a noob at c
Not me, I'm pretty damned good at this if I must say so.
please give me a really basic example,
After you called me a cunt earlier?  I see you took it down, but I saw it.  Maybe a sorry would help.
the serial buffer normally gets outputted to the lcd screen,
No, not normally.  Normally the two have nothing to do with one another.  Nothing gets sent to the lcd unless you send it there in your code.  That's why I asked for context.  Are you talking about a serial lcd?  Are you talking about the send buffer or receive buffer?
but the lcd is 16, 1 and fills up and stops any more input and even puts in strange chars if i try to add more in
So don't send so much to the lcd.  You have control over what you send from your code.
so maybe i need to use the lcd.clear but then it might just fill with the serial buffer again and it wont achieve any clearing, so i think clearing the serial buffer aswell as lcd.clear will work a lot better but have no idea what the code to do that is.
I have no idea what that code is either because I know practically zero about your project or which components you have or the code you are using.  If you want help, then you'll have to be forthcoming about those details.
And don't call people ugly names.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
multimedia
i dam well just told you lcd 16,2 standard arduino kit screen thats it and esp 8266
Delta_G
There are many kinds of LCD.  Which one do you have?  How does the board communicate with it?  Serial?  I2C?  SPI?  Parallel?
I'm still not clear on the connection between the serial buffer and the LCD in your program.  That's something else you should explain.
So we know you have some kind of LCD and an eap8266 and that's all you've given me.  And I'm supposed to know what code you need to do some as yet unnamed thing just from that?  Are you serious?
Or you can just keep being combative and get nowhere.  I'm stuck at an airport so I honestly have nothing better to do. So I really don't care.
|| | ||| | || | ||  ~Woodstock
multimedia
omfg, soooooooo many questions and they are dumb ones! its a standard means theres no model number no make nothing just google standard 16,2 arduino lcd kit and it dont matter they are all same except mine has i2c board again a standard thing look for the most common i have that, simples! h/w dont even matter its a software thing!
Delta_G
Hardware determines how you write the software.
Sorry, but all lcds are not the same.  They really aren't.  And there's no such thing as a "standard" one.
But that's not the really big question. The real question is about what the code is doing with this serial data and what's being put on the LCD.
I'm not being obtuse. I honestly don't know what it is that you're trying to do with this code.  I can tell you I've never had a problem writing stuff to any LCD.
But hey, if you don't want to answer these things then don't. I can tell you that you won't get a solution that way but that's your prerogative.
Actually, come to think of it I'm pretty much done with this.  You're combative, don't want to answer simple questions, and you called me an ugly name.  So I'm out. Maybe if you post some details someone else will help you. But as for me I'm pretty much done with you.  A slightly different tact on your end and you'd have working code by now. But you're just a waste of time I think.  Good luck figuring it out.
|| | ||| | || | ||  ~Woodstock
multimedia
no the ide compiles depending on options! just give me code and i will test :) plz
NischalSehrawat
Would it be better to write a small function to clear the buffer instead of doing serial.end/serial.begin as this may fragment memory.
Code: [Select]
void serialFlush(){
  while(Serial.available() > 0) {
    char t = Serial.read();
Hi, Can you please explain how will this line of code empty the serial buffer?
zoomx
void serialFlush(){
  while(Serial.available() > 0) {   //while there are characters in the serial buffer, because Serial.available is >0
    char t = Serial.read();         // get one character
multimedia
I basically made an lcd display that uses a file / path requests from a form all to save having to use sd card for displaying things but want to be able to rewrite it and the program know if new input detected if yes then change sort of thing but im novice and not got a clue the best way to do this, it sort of works but not stangle due to after a long while it clears itself anyone help?
Delta_G
What's your native language OP?
|| | ||| | || | ||  ~Woodstock
multimedia
irrelevent stick to the topic!
Delta_G
#26
Jun 07, 2018, 03:09 pm Last Edit: Jun 07, 2018, 03:11 pm by Delta_G
Relevant, beccause you aren't making much sense when you type and I thought if you are not a native English speaker I would help you find the forum where they speak your language.
If English is your native language then please take a little more care when you type to make something that is readable by others.  Incude maybe some punctuation or something.  You're asking a bunch of professionals for help, you're not typing a text message to your boyfriend.  Try to look at least mildly intelligent if you want anything other than the dregs to try to help you.
|| | ||| | || | ||  ~Woodstock
GolamMostafa
#27
Jun 10, 2018, 02:20 am Last Edit: Jun 10, 2018, 02:22 am by GolamMostafa
Hi all,
          i had this question a few weeks back , after the change in flush() method it had become quite difficult to empty the serial buffer , [...].
Unfortunately, I could never figure out the meaning/significance ofemptying the serial buffer.
A: Emptying the Serial Buffer of the Receiver Section
Data comes to the receiver one character at a time. When the character arrives, it is immediately read upon and is saved in an user defined array. If so, how a serial buffer can get full and such we need to empty/flush it after reading the data. It is only one byte long buffer as I understand. If we don't read the character that has  just arrived, there is a possibility that the character byte might be overwritten by the arrival of the next character. Therefore, the speed of data read must be higher than the speed (the Bd) at which data arrives.
B:  Serial Buffer of the Transmit Section.
In UART Protocol, one character is transmitted at a time. If so, the execution of the command Serial.print("Arduino"); requires that there should be an intermediate buffer to hold the characters of the message Arduino. As I understand, the transmission of Serial.print("Arduino"); is composed of the following 7 sub transmissions:
Code: [Select]
Serial.print('A');
Serial.print(r');
Serial.print('d');
Serial.print('u');
Serial.print('i');
Serial.print('n');
Serial.print('o');
How much (in byte) is the length of the serial buffer of the Transmit Section?
Delta_G
Both buffers are 64 bytes on most boards.
It's defined in HardwareSerial.h
Code: [Select]
#if !defined(SERIAL_TX_BUFFER_SIZE)
#if ((RAMEND - RAMSTART) < 1023)
#define SERIAL_TX_BUFFER_SIZE 16
#else
#define SERIAL_TX_BUFFER_SIZE 64
#endif
#endif
#if !defined(SERIAL_RX_BUFFER_SIZE)
#define SERIAL_RX_BUFFER_SIZE 16
#else
#define SERIAL_RX_BUFFER_SIZE 64
#endif
#endif
#if (SERIAL_TX_BUFFER_SIZE>256)
typedef uint16_t tx_buffer_index_t;
#else
typedef uint8_t tx_buffer_index_t;
#endif
#if  (SERIAL_RX_BUFFER_SIZE>256)
typedef uint16_t rx_buffer_index_t;
#else
typedef uint8_t rx_buffer_index_t;
#endif
|| | ||| | || | ||  ~Woodstock
GolamMostafa
#29
Jun 10, 2018, 03:00 am Last Edit: Jun 10, 2018, 03:01 am by GolamMostafa
Delta_G, it is just an academic query:
If the buffer size of the Transmit Section is 64 byte, only 64 characters of the following message should be transferred and the remaining characters are either lost or queued somewhere. Practically, it is observed that the whole text has appeared on the Se rail Monitor.
Code: [Select]
Serial.println("//put your setup code here, // put your setup code here, to run once: // put your setup code here, to run once: // put your setup code here, to run once:");
