Topic: Arduino Ethernet Board Hardware Problem (Read 5916 times) previous topic - next topic
realfcbstuff
Apr 19, 2014, 11:07 am Last Edit: Apr 19, 2014, 11:09 am by realfcbstuff Reason: 1
I am currently modifying and developing based on arduino ethernet board to interface with a relay and fpc connector.
http://arduino.cc/en/Main/ArduinoBoardEthernet
I would like to ask regarding this component :
5   10u   CPOL-EUSMCB   SMC_B   C8, C11, C13, C18, C19   POLARIZED CAPACITOR, European symbol
I realized these are the decoupling capacitors for the arduino ethernet board.
However, based on my observation these capacitors on the original board are non-polarized capacitors.
May i know should i be using a polarized one or non-polarized capacitor in this part?
Many thanks
SpikedCola
Typically decoupling caps are ~100nF - I'd be inclined to think these are tank caps for the power supply instead.
Regardless, it doesn't matter whether you use polarized or non-polarized, as long as the orientation is correct :) You could use 10uF ceramics, which are (almost always) non-polarized, or you could use 10uF aluminum caps, which are (usually) polarized.
realfcbstuff
I see, this means that if i use non-polarized cap, the orientation doesn't matter and when i use polarized cap, the orientation matters right?
realfcbstuff
