Topic: i2C PIC Code 2 Arduino (Read 932 times) previous topic - next topic
jl-p
Apr 20, 2014, 02:44 pm Last Edit: Apr 20, 2014, 03:21 pm by jl-p Reason: 1
I have a 7"display but the only examples i find are pic examples (i think)
I ported the SPI version for the display already from that to arduino and that works as expected.
But now i'm busy with the I2C code so i can choose which connection i want. and make a library for it.
I don't know if its necessary but i will use it on my due
but i have a couple of Wire issues i'm not sure off.
I think the only functions which needs to be corrected are the
master_ACK
slave_ACK
IIC_WriteByte
IIC_ReadByte
so i think start en stop voids can be removed
Start() and stop()  changed for Wire.beginTransmission(); and Wire.endTransmission();
Code: [Select]
sbit  MCU_RST=P2^3;
sbit  SCL=P1^1;
sbit  SDA=P1^0;
sbit next =P2^7; //next
bit ack;
#define write_data_addr  0x0c  //slave addresses with write data
#define read_data_addr  0x0d  //slave addresses with write data
#define write_cmd_addr  0x0e  //slave addresses with write command
#define read_cmd_addr  0x0f  //slave addresses with read status
//I2C_Init()
void SPI_Init(void)
// SCL = 1;
// SDA = 1;
        wire.begin();    //         i think only this line instead of the two above
//start
void start(void)
SDA=1;
delay(1);
SCL=1;
delay(1);
SDA=0;
delay(1);
SCL=0;
delay(1);
//stop
void stop(void)
SDA=0;
delay(1);
SCL=1;
delay(1);
SDA=1;
delay(1);
SCL=0;
delay(1);
//Host sends an ACK
//ack=0  ACKNOWLEDGE  ack=1 NOT ACKNOWLEDGE
void master_ACK(bit acknow)
{ SDA=acknow;
delay(1);
SCL=1;
delay(1);
SCL=0;
delay(1);
//Slave sends ACK
void slave_ACK(void)
{uchar i=0;
delay(1);
SDA=1;
delay(1);
SCL=1;
delay(1);
while((SDA==1)&&i<200)i++;
delay(1);
SCL=0;
delay(1);
//*********I2C send byte
void IIC_WriteByte(uchar Byte)
{uchar t;
for(t=0;t<8;t++)
  { delay(1);
    SDA=(bit)(Byte & 0x80) ;
    Byte <<=1;
delay(1);
    SCL=1;
delay(1);
    SCL=0;
delay(1);
slave_ACK();
//*********I2C Read byte
uchar IIC_ReadByte(void)
{uchar t,read_data=0;
SCL=0;
delay(1);
SDA=1;
delay(1);
for(t = 0; t < 8; t++)
{ delay(1);
SCL = 1;
delay(1);
read_data<<=1;
if(SDA == 1)
read_data=read_data|0x01;
SCL=0;
master_ACK(ack);
return read_data;
void LCD_CmdWrite(uchar cmd)
IIC_WriteByte(0x0e);
IIC_WriteByte(cmd);
//////////////SPI Write data or  parameter
void LCD_DataWrite(uchar Data)
IIC_WriteByte(0x0c);
IIC_WriteByte(Data);
///////////////Read data or  parameter
uchar LCD_DataRead(void)
uchar Data;
IIC_WriteByte(0x0d);
ack=1;
Data=IIC_ReadByte();
return Data;
///////////SPI Read  status
uchar LCD_StatusRead(void)
uchar Data;
IIC_WriteByte(0x0f);
ack=1;
return Data;
Already Thanks
Johan
jl-p
#1
Apr 20, 2014, 11:41 pm Last Edit: Apr 20, 2014, 11:43 pm by jl-p Reason: 1
I have this right now.
But no luck with the screen.
first command i send is a 0x00
which should be acknowledged with a 0x75
i see i get a 0 back but when i disconnect the screen i also receive a 0
Code: [Select]
void LCD_CmdWrite(unsigned char cmd) {
 Wire.beginTransmission(write_cmd_addr);
 Serial.println(cmd,HEX);
 Wire.write(cmd);
void LCD_DataWrite(unsigned char Data) {
 Wire.beginTransmission(write_data_addr);
 Serial.println(Data,HEX);
 Wire.write(Data);
unsigned char LCD_DataRead(void) {
 unsigned char Data;
 Wire.requestFrom(read_data_addr, 1);
 while (Wire.available())  {
   Data =  Wire.read();
   Serial.println(Data, HEX);  }
 return Data;
////////////////Write command and parameter
void Write_Dir(unsigned char Cmd, unsigned char Data) {
 LCD_CmdWrite(Cmd);
 LCD_DataWrite(Data);
unsigned char LCD_StatusRead(void) {
 unsigned char Data;
   Data =  Wire.read();}
 return Data;
jl-p
I think i have it. although the screen isn't working yet but i see responces which looks according the datasheet correct.
So if it work i will update this thread with the solution for other users.
