Topic: Can't debug Code, to show change in temperature as colour with a RGB (Read 10263 times) previous topic - next topic
Ben1999
Hi
I am trying to show the change in temperature(degrees centigrade), with different colours with a RGB Led.  It worked with the first few colours, but started to mess up when I added more detailed colour instructions.  I am trying to figure out the bugs, but it would be great if I would get some help.  Thank you for the help.
Code: [Select]
int temperaturePin = 0;
int LED[] = {9, 10, 11}; //sets the pins
                         //9 = RED, 10=GREEN, 11= BLUE
const boolean ON = LOW;  //defines ON as LOW
const boolean OFF = HIGH;  //defines OFF as HIGH
//Predefined Colors
const boolean RED[] = {ON, OFF, OFF};
const boolean GREEN[] = {OFF, ON, OFF};
const boolean BLUE[] = {OFF, OFF, ON};
const boolean YELLOW[] = {ON, ON, OFF};
const boolean CYAN[] = {OFF, ON, ON};
const boolean MAGENTA[] = {ON, OFF, ON};
const boolean WHITE[] = {ON, ON, ON};
const boolean BLACK[] = {OFF, OFF, OFF};
     for(int i = 0; i < 3; i++){
   pinMode(LED[i], OUTPUT);   //Set the three LED pins as outputs
  Serial.begin(115200);  //Start the serial connection with the copmuter
                       //to view the result open the serial monitor
                       //last button beneath the file bar (looks like a box with an antenae)
* getVoltage() - returns the voltage on the analog input defined by
* pin
{float getVoltage(int pin);
return (analogRead(pin) * .004882814); //converting from a 0 to 1023 digital range
                                        // to 0 to 5 volts (each 1 reading equals ~ 5 millivolts
} //converting from a 0 to 1023 digital range
float temperature = getVoltage(temperaturePin);  //getting the voltage reading from the temperature sensor
temperature = (temperature - .5) * 100;          //converting from 10 mv per degree wit 500 mV offset
Serial.print(temperature); Serial.println(" degrees centigrade");
if(temperature < 430){
  setColor(LED, BLUE);
else{
  if(temperature >430 && temperature <440){
    setColor(LED, GREEN);}
      else {
        if(temperature >440 && temperature <450){
      else{
        setColor(LED, BLACK);
void setColor(int* led, boolean* color){
   digitalWrite(led[i], color[i]);
void setColor(int* led, const boolean* color){
  boolean tempColor[] = {color[0], color[1], color[2]};
  setColor(led, tempColor);
johnwasser
This should help some.
Code: [Select]
int LED[] = {
//Predefined Colors
  ON, OFF, OFF};
  OFF, ON, OFF};
  OFF, OFF, ON};
  ON, ON, OFF};
  OFF, ON, ON};
  ON, OFF, ON};
  ON, ON, ON};
  OFF, OFF, OFF};
   * pin
  else{
    else {
      else{
  for (int i = 0; i < 3; i++) {
  boolean tempColor[] = { color[0], color[1], color[2]  };
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
AWOL
Your code doesn't compile, so debugging is some way off.
One useful technique is to first make your code more legible, but you'll soon find that the auto format tool doesn't work on the code you posted, giving you the useful clue "Too many left curly braces".
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
