Topic: Female headers similar to Arduino (Read 9647 times) previous topic - next topic
JamesCarruthers
I am building a little stripboard prototype and I want to use the female headers that are similar to the ones on the Arduino - but not sure what to call them or how to find them (I'm looking on Farnell).
Either that or something similar - I want to be able to stack another stripboard on top of these.
florinc
This is the keyword for search (google, farnell, digikey etc):
"40-Pin Female Header"
RoyK
http://www.sparkfun.com/commerce/product_info.php?products_id=115
jabber
RS Components refer to them as "top entry socket", finding them on the RS site is like the proverbial needle/haystack etc.
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=4881730
They have to be cut down to size.
Folderol
RS don't you just love 'em ;D
Actually you can get a range of sizes. Try
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=retrieveTfg&Ne=4294960188&Nr=AND%28avl%3auk%2csearchDiscon_uk%3aN%29&N=4294918229+4294955272+4294911654&Ns=stockPolicy_uk|1||new_uk|1&multiselectParam=4294918229%204294955272&selectAttribute=Socket#breadCrumb
TBAr
Quote
Have a look at the shield stacking headers from AdaFruit.
JamesCarruthers
#6
Aug 22, 2009, 10:06 am Last Edit: Aug 22, 2009, 10:09 am by jcarruthers Reason: 1
Thanks for the RS links - have to say that I prefer Farnell - free postage and they deliver stuff next day even if you order it reallllllllly late.
While I like to support the Arduino vendors etc - I must say I prefer to find them direct - it's usually far cheaper even if it takes an extra 10 mins to find.
(not that I can find those bits on the Farnell site)mail
JamesCarruthers
Here's what I found on Farnell
http://uk.farnell.com/samtec/ssw-112-02-g-s/receptacle-2-54mm-single-12way/dp/1668382
http://uk.farnell.com/samtec/ssa-114-s-g/receptacle-2-54mm-pcb-14way/dp/1668228
jabber
If you do order from RS/Farnell  etc, have a look at the specs/drawings first because some of the headers are not very tall.
n00b
i get my ones from http://www.bitsbox.co.uk/connects.html
where they are called Single Row Sockets, and come pre cut as 2,3,4,8,16 and 25.
And much cheaper then the big on-line stores!
JamesCarruthers
Thanks for that - Bitsbox looks great.
JamesCarruthers
www.coolcomponents.co.uk also does them - useful site
mungbean
oh pre-cut ones, nice one.
anyone worked out a good way of cutting the 40-way ones to size?  I've tried wired cutters, knife, side cutters, but they nearly always break in a way that means the end contact falls out :-(
I don't know why they can't pre-score them like the male equivalent.
kg4wsv
You will always lose one pin with the female headers.  Trying to cut them without sacrificing one means you'll lose 2 instead of 1 (and maybe trash the whole thing in the process).
I use a dremel tool with abrasive cutoff wheel (preferred method) or small sharp diagonal cutters (decent second choice) to cut directly down the center of the sacrificial pin.
-j
mungbean
great tip!  counter-intuitive, but cutting right on the "sacrificial pin" does it perfectly.
