Topic: Female headers similar to Arduino (Read 8991 times) previous topic - next topic
retrolefty
Then a little smoothing of the cut surface with a file or sandpaper and it will look like store bought  ;)
Lefty
jabber
I know it's a bit late, but the RS link I posted above is for the DIL socket, not the SIL version. Guess who just took delivery of some ::).
sourcery
Here's also stackable headers, that also includes a stackable ICSP connector. Just a weeeeeee bit cheaper than the adafruit (0,01$) ;)
http://www.nkcelectronics.com/arduino-stackable-header-kit.html
Just ordered from them (intl.). They seem to have quite a good stock of arduino related stuff.
/Kristian
kg4wsv
+1 for the NKC headers.
I bought several sets last time I ordered from NKC.  They work well, and look better than the headers I cut to fit.
-j
condemned
#19
Sep 08, 2009, 10:23 pm Last Edit: Sep 08, 2009, 10:27 pm by condemned Reason: 1
In case it's helpful for bigger orders, I've found two main sources for these long-square-tailed-female-headers.
The first is Samtec:
     SSQ-108-03-G-S
     SSQ-106-03-G-S
They're pretty pricey, but they do deliver very quickly.
The second is Don Connex (whose UK distributor is Toby - they've already been mentioned)
     B06b-1x6-AGC1-G
     B06b-1x8-AGC1-G
I'd happily recommend Toby by the way. Friendly and efficient.
There's a third source, which is 4uconn, but I don't think their tails are quite square (but I'm not sure that matters). Their part numbers are 18688 and 18689.
The samtec parts above are the gold-flash version. Below is a picture of the matte-tin finish version.
[edit: And, as is often the case, I've completely misunderstood the question! - My waffling was for the long-tailed headers that are suitable for stacking shields - the OP just wanted standard female headers... Oh well, someone might find the info useful <sigh>]
PixelFreak
I sell the samtech ones over here.
http://www.protostack.com/index.php?main_page=index&cPath=5_8
The samtec ones are a little bit pricier, but the quality is very good. I've seen a lot of the cheaper ones get loose after a few insertions.
Daniel.
vxir
Also, if you pull the "sacrificial" pin out with needlenose pliers first it makes it a lot easier to cut!
Reggie
Amen to the sacrificial pin Vxir, the ICSP header could be made out of a chopped 8.  It just dawned on me that the ICSP stack would go upside down to be useful....
