Topic: smallest arduino board? (Read 16238 times) previous topic - next topic
whosawhatsis
I got some new boards in, but I can't assemble them yet because I ran out of sockets. I've got some on the way, but until then I thought I'd show off the bare boards.
At the top is a board with built-in usb. I made a mistake on this one that I didn't notice until after I sent my order, so I had to cut a trace in a couple of places. This board also had some slight manufacturing defects in the solder mask, but nothing that should affect functionality.
The next one is like the last version, but with icsp added and a bunch of cleaning-up done to the trace routing and silkscreens.
The last one is a mini version. Like the very first one I made, it is designed to be powered either by the ftdi cable or an external regulated supply. This one is even even smaller though, at about .66 square inches.
Each of these also has a solder jumper so that auto-reset can be disabled.
The_Bongmaster
B-dui in creation.
Mike Perks
#32
Jun 24, 2009, 07:48 am Last Edit: Jun 24, 2009, 07:49 am by mikeperks Reason: 1
You are making good progress with these boards. I like the idea. If you want to see what is possible with SMD parts, check out my own om328p with Arduino bootloader.
Mike Perks
OakMicros.com
Mike Perks
oakmicros.com
See our om328p Arduino Compatible
whosawhatsis
salsaman
These are just awesome!  I'm completely sold on breadboardable *duinos.  Looking forward to getting more access to the rows than what iDuinos and Boarduinos offer.  Curious if you've consider a jumper header for getting power to the rails instead of running two leads, to further free up breadboard space.
My Arduino blog: http://jmsarduino.blogspot.com
Comprehensive (?) Arduino-compatible board list: http://tinyurl.com/allarduinos
whosawhatsis
A jumper header? I'm not sure how that would work, but it sounds interesting. Can you explain what you have in mind?
whosawhatsis
Oh, did you mean something like this?
You could certainly assemble any of them (except for the super-tiny one with no onboard power regulation) with male or female headers facing up. With long-lead headers, you could do that and still connect them to the breadboard.
salsaman
Yes, something like that-- a way to get power to the rails without using up  rows on the sides, freeing up a few rows adjacent to i/o pins for whatever is needed; maybe not that useful...:P
whosawhatsis
#38
Jul 21, 2009, 08:38 pm Last Edit: Jul 21, 2009, 09:02 pm by whosawhatsis Reason: 1
Here's another project I made with it:
Capacitive sensor array
whosawhatsis
#39
Jul 27, 2009, 08:11 pm Last Edit: Jul 27, 2009, 08:20 pm by whosawhatsis Reason: 1
I'm looking for a way to replace the resonator with a crystal, but space is very limited, and I need to add capacitors with that. I'm playing with some SMD designs, but I really want to keep this one purely through-hole (I've also decided to stop working on the usb version). I'm thinking that a cylindrical package could work, but I can't find any that are less than 8.8mm long, and I only have a clearance of ~ 7mm. Anyone know of a 16 mhz cylinder crystal that's shorter, or know if it would be a problem to mount it at 45 degrees, or laid flat above its capacitors? I've never used one before, but what I've read suggests that they're more sensitive about their environment than other components.
mlezine
hello whosawhatsis, is it possible to have a pcb layout in eagle or other format? thanks a lot.
whosawhatsis
All of my designs are kinda in flux, I haven't been keeping old versions of the files like I probably should have, and the current versions are all untested and need a lot of cleanup. I'd really rather wait until the "final" version to distribute the files.
In the meantime, here's a peak at my newest design. It's a similar concept (tiny, breadboardable arduino with a .3" span), but this one is all-SMD. BTW, I never would have guessed that a TQFP would be easier to solder than a 603...
The_Bongmaster
lookin good :)
i havnt tried a smd type arduino yet.
B-dui in creation.
Mike Perks
Quote
There aren't any cylindrical crystals shorter than 8.8mm that I know of. The ECS is slightly shorter than the Citizen one and doesn't exactly match the datasheet dimensions.
It is possible to put the crystal on top of other components and in particular the AVR chip. See the OakMicros om644p for an example. of course the mega328p is a smaller chip than the mega644p. You should avoid long traces for the crystal and have the caps also close by. I think a crystal is far superior to a resonator as it is more accurate and less prone to drift.
Mike Perks
oakmicros.com
retrolefty
Check the size of the 16mhz crystal used by the Seeeduino Mega, it's the package closest to the avr1280 chip and measures about 4mm X 3.2mm.
http://www.seeedstudio.com/depot/seeeduino-mega-fully-assembled-p-438.html?zenid=9f6118c193cee9f8b7337d4df91a2eca
Lefty
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
