Topic: Bike interface OBD (Read 85650 times) previous topic - next topic
aster94
#150
Oct 26, 2018, 09:16 pm Last Edit: Oct 27, 2018, 01:46 am by aster94
Hi guys!
I am veeery near to finish a project which i have worked since some times: a library to make the communication with motorbikes which uses the keyword protocol 2000 easy for everyone, in the last months i gained quite a good knowledge about this protocol and obviously i am ready to share it :D
this is my almost finished attempt:
https://github.com/aster94/Keyword-Protocol-2000
I was wondering if someone would like to contribute with the kawasaki/honda/yamaha part, i know almost nothing about these bikes but they should be using the same protocol and all the code is already settled for them
Right now i am testing this on a suzuki GSX-R 600 L1 (2011) but it doesn't respond to the start sequence. I am not sure which is the problem but i guess some echo or maybe suzuki stopped using the KWP before 2011 :(
EDIT: be aware that the documentation on github is not up to date
TriB
nice to see how far you got!
I just throw an eye on you code and it will not be able to cover Suzuki and Kawasaki.
What you called PID, is the place of a specific value within the response data. Because Suzuki gives you all information in a single request. But in OBD II and KDS, the PID is per request.
Give me RPM out->0x0C  in<-2500rpm.
That is hard to combine and you more or less double the code with two different approaches. I´m somewhere on half way there. It works, but SDS is quite slow, due to the fact I does not store the values right now.
Me also got everything running and then, from one day to the other my ECU did not respond to the init protocol anymore.
In my case, it was my datalogger. It sends all outgoing and incoming data to a second arduino, which does all the SD-stuff. Sending a single request took 0,012 secs. But it seems to be enough, that my Suzuki GSX-R600 K6 does not respond anymore. Deactivating that, instantly made it work again. Try it with you debugging-mode.
aster94
#152
Oct 28, 2018, 03:17 pm Last Edit: Oct 28, 2018, 07:19 pm by aster94
Hi trib,
I know that kawasaki needs to ask for every single sensor
this is the reason for a couple of defines in my code: see here and then this
This way calling just one function which is requestSensorsData on both suzuki and kawasaki on suzuki will send just one request (0x21, 0x08) while in kawasaki it will send a group of request :smiley-razz:
EDIT: it seems that it wasn't my fault https://github.com/espressif/arduino-esp32/issues/2004
Bullone
Hi guys,
thanks for all the great informations!
I have an Yamaha Tracer 900 2018 and I suppose my bike is using CAN bus on the diagnostic connector... can you help me to implement an Arduino based board to read some data (TPS, RPM...) via CAN? Is it possible?
TriB
Hi Bullone,
what makes you think that Yamaha uses CAN-Bus?
They are still on K-Line as Suzuki and Kawasaki.
But what changed due to the 2018 EURO6 is, that it is OBD2 compatible.
These are two different things!
CAN-Bus is the way data is sent between ECU, sensors / actuators and diagnostic plug.
K-Line is the way how the diagnostic plug sends and receives data via single line. Sensors and stuff is just communicating by it´s voltage/resistance.
OBD2 is only the language how it speaks to you.
What you can do is to connect a stock ELM327 OBD2 Plug to you diagnostic Plug. Since OBD2 is compatible, you can use it right from the start, like in a car.
No value calculations, no PID translations, ect.
You only need to know which wire is the K-Line, Ground and Voltage, to connect it equivalent to the ELM327 Dongle.
Good luck :)
Bullone
Hi Bullone,
Good luck :)
Wow! Thanks for the info!
I was supposed that on the DLC connector of the recent bike I have to "read" CAN bus data.... have you ever work on Yamaha DLC? I'd liek to do an Arduino board to read TPS, RPM and ECT from the DLC
TriB
No, I haven´t. But since this is standardized, it should be easy as nuts!
Pinout can be found here on Wikipedia.
And here is how to connect it onto your bike. There are several online-shops which sell a connector (for a lot of money). But you can do it by yourself for testing purpose.
Then install Torque, Car Scan or a simple Bluetooth Terminal on your phone, to test the connection.
Bullone
Thank you so much!
Looking on the link you post it make me back confused.... the diagnostic connector has 4 pins: +12V, GND, CAN HI and CAN LOW.... also on the OBDII connector the pin6 and 14 are related to the CAN bus. That means that the diagnostic use CAN instead of k-line?
Sorry but I'm confused, probably my fault! :)
Bullone
What about this post?
https://www.fz09.org/forum/6-fz-09-general-discussion/5491-data-logger-plug-play-devellopement.html
TriB
This is from 2010, as you can see. It also uses K-Line to communicate with the diagnostic interface, like we do here.
As you have said, the new bike from 2018 uses CAN. So how should that help?
And why you don´t follow my idea with an OBD2 dongle?
OBD2 dongles support several communication types (As K-Line and CAN).
Get your bikes diagnostic plug-pinout and combine it with my wiki-link to the ELM327 (OBD2 dongle) pinout.
That´s it!
The ELM327 makes everything for you. You won´t see if it uses K-Line or CAN.
Bullone
Thanks for all the info!
The DLC connector has 4pins: CAN+, CAN-, +12V and GND
aster94
I am enough happy with my library and finally I am ready to promote it to version 1.0.0 and to pubblish it!
Keyword Protocol 2000
This would help you make the interface between motorbikes/cars and arduino easier
Get me on github and tell me if you test it so i can upgrade the list of tested bikes!
TriB
Nice one, @aster94!
Really a lot of work in it.
Currently I am recreating my Gsx-R due to a little accident on a racettrack. But I´ll test your code on both, my K6 and my Kawasaki Z750r.
My solution also does both, but it got less interfaces. My goal was different, I made it OBD2 compatible, so there are plenty of duplicated codes (for conversion, clear diagnostic, and more).
Maybe I´ll try to combine the best of both worlds, when I got time for that.
aster94
Nice one, @aster94!
I hope you are ok and I am sure that your bike will get better then before :D
when i started to write this i had to decide between OBDII and KWP2000, both had pro and cos but at the end i choosed for the KWP because it would be faster since it doesn't have to "traslate" request/responses, obviously this also means that my code is less portable!
I can confirm that there is a lot of work in it, it stated as a hobby project but I guess you can understand that soon it took me more time than expected ahahah
CapFirepants
#164
Mar 27, 2019, 07:08 pm Last Edit: Mar 27, 2019, 07:09 pm by CapFirepants
Hey Aster
I posted here about a year ago and finally got around to trying out something. I loaded your library up onto my arduino uno and tried the example sketch you have on github.
My bike is a honda CB500F (PC45) 2013 Model.
I tried to uncomment the honda but got this error message while compiling:
Code: [Select]
C:\Arduino\libraries\KWP2000\src\KWP2000.cpp: In member function 'void KWP2000::requestSensorsData()':
C:\Arduino\libraries\KWP2000\src\KWP2000.cpp:505:19: error: 'request_sens' was not declared in this scope
     handleRequest(request_sens, LEN(request_sens));
Using library KWP2000 at version 1.1.0 in folder: C:\Arduino\libraries\KWP2000
I went to look into the code and saw your comment about the yamaha and honda being probably the same, so I tried uncommenting just the yamaha and was able to compile.
Next, I hooked up my setup to the bike and tried reading data. The output I got back is attatched. I'm not really sure that it's what I should be getting - as soon as the ECU turned on it would not stop sending out data...maybe you could advise me here?
I'd really like to get this working and help you to extend your library. If you could tell me where to start, that would be great!
Also, here some pictures of my setup. The mess of hotglue is the L9636 chip with dupont wires soldered to the appropriate pins. Crude, but it works. I didnt have any 510 Ohm resistors, so I took 2 1k in parallel - should be fine, right?
https://imgur.com/a/I1a5Yit
