Topic: Stepper Motor Based Linear Actuator (Read 4950 times) previous topic - next topic
OSOO
Hello,
I want to use Arduino to control a stepper motor based linear actuator ,I want to use this stepper to drive a simple syringe filled with fluid in a range of 1 to 10ml  ,please can you suggest me an online shop where I can find  a suitable stepper motor for my application ? Please help I need it ASAP ,I would be so grateful
Robin2
You will need to know a good deal more than you have posted in order to select a suitable motor.
There are several (maybe dozens) of on line suppliers. Where are you located?
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
raschemmel
Whatever solution you choose it will need to include micro-stepping. That is a feature that is not included in many stepper drivers.
Arduino UNOs, Pro-Minis, ATMega328, ATtiny85, LCDs, MCP4162, keypads,<br />DS18B20s,74c922,nRF24L01, RS232, SD card, RC fixed wing, quadcopter
OSOO
I live in Yemen(middle east)
could you please see this link :
http://www.haydonkerk.com/LinearMotionProducts/StepperMotorLinearActuators/tabid/66/Default.aspx
These motors can be used for micro-stepping ,but please I have some questions:
what is the difference between captive ,non-captive ,and external stepper ?
how I can know the diameter of the screw ?
in my application ,do I plug the actuator to the syringe directly !?
raschemmel
OSOO
Guys please is there a way to buy Haydon products over the net
jremington
What is the minimum volume of fluid that you intend to dispense?
How accurate must this volume be?
raschemmel
#7
May 03, 2014, 08:05 pm Last Edit: May 09, 2014, 07:20 pm by raschemmel Reason: 1
Quote
Have you heard of email ?
TomGeorge
Hi, sounds like you are trying to imitate an insulin infuser that a lot of diabetics wear these days to provide small almost continuous supply of insulin to keep their blood sugars stable.
Have you tried looking in the medical or laboratory field, I know they will be expensive, but the theory and practice may help your implementation.
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
OSOO
0.1 - 1 ml / hour
my application requires a very high accuracy :)
OSOO
Tom... :)
Yes that is true , my project is to control the infusion of medical solution using microcontroller :)
I only need the linear stepper motor actuator ,I have found a number of these medical infusers ,but I want to make my own assembly.
OSOO
Quote
I sent many emails to 3 companies, but I have not received a response ,so this is why I asked the question, If there is an online store where I can find linear stepper motor actuators ,that would be great :)
jremington
This linear actuator may be suitable for driving a syringe pump, but it is still quite coarse compared to many others available. To get higher resolution you need a lead screw with a finer pitch. http://www.pololu.com/product/2268
OSOO
Thanks guys,
I have one more question please, How could I determine the force required to exert on the syringe ?
jremington
Usually that is  not an issue. Most motors, geared down by a lead screw, are very powerful compared to the resistance offered by a syringe driving a tiny fluid flow.
