Loading...
Pages: 1 ... 3 4 [5]   Go Down
Author Topic: Available shields and shield ideas  (Read 3042 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
Quote
I had seen that and I thought that I had added it to the list already but apparently not... It looks good.
I will be buying one of those, It would also be a good prank board!
Mowcius
I hadn't thought about using this for pranks?  smiley-wink
If you do create a prank with this board I'd love to see it in action.
- Eric
Logged
Offline Offline
Full Member
Arduino rocks
View Profile
@Inopia
Quote
Why don't you get an xbee shield if you want Zigbee?
I know I can.
As previously stated "I suggest that your cheap node implementation be at least Zigbee compatible so it is marketable."
I'm only suggesting this to help you.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
@novice, vixr: Zigbee compatibility comes on two levels. On one hand you have the radio that implements the physical and MAC layers, and a network layer that performs routing, among other things. On the other hand you have modules such as xbee that allow you to talk over zigbee from an MCU, usually via serial. These modules have their own MCU that implements all the zigbee stuff in software.
If you save money by eliminating that MCU and doing everything on the AVR you're going to have to run a network stack on the AVR along with your application, so the second case of zigbee compatibility obviously does not apply. The first case is a matter of implementing a standard. The biggest problem is that if you run both the network layer and applications on one chip you're going to need something that enables multiple threads of control (and no, interrupts aren't going to cut it). Several such systems have been proposed using 'real' multitasking/threading (Mantis, freertos), protothreads (Contiki), and event-based programming (TinyOS). Personally I prefer Contiki although my goal is to just do everything in Java and use green threads.
So 'Zigbee compatibility' requires either a second MCU (which is what xbee modules have) or a more advanced 'os' or runtime or library or whatever that lets you do multithreading in a sane way. If you want complex network features you're going to need something other than the Arduino language. For robotics/wsn I'd suggest you take a look at Contiki (http://www.sics.se/contiki/about-contiki.html), which has a wireless stack called RIME that's already running on the AVR Raven boards which use about the same setup as what we've been talking about (avr+atmel 2.4ghz rf), so should be trivial to port. It's IPV6 baby :3
For just simple point-to-point communication in the absence of another 2.4ghz network on the same channel you can just send raw packets over the radio. Control your Philips ambilight and such smiley It's perfectly fine for applications such as controlling your coffeemaker wirelessly. You only need Zigbee or something like that for large scale, multi-hop networks, or for integration with existing Zigbee stuff.
As for open sourcing I already open source my efforts under the LGPL license, my JVM can be found at http://darjeeling.sourceforge.net/.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
So I've done a little digging and found a software library for the AT86RF2xx chips from Atmel:
http://www.nongnu.org/uracoli/links.html#RCB230
It seems to do all sorts of cool stuff from low-level to high-level, such as mesh networking or simple wireless uart.
Logged
Offline Offline
Full Member
Arduino rocks
View Profile
Inopia,
does that communications library put you in a position to make hardware decisions?. It appears that vxir is 'keen as mustard' to help you on the h/w side.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Hi guys, I've worked up some spreadsheets of components and prices.  I'm ok with the AT86 chips, esp since they also do Zigbee (802.15).
The key question is "can the SW be done within a single AVR or is a separate dedicated 1281 required?"
Frankly, there seem to be a lot of hardware choices in the "not-quite Arduino compatible" department (dig into Inopia's link and you see a bunch), and there is the Arduino/XBee solution.
So we have to fit in this ecosystem.  I think that that means 100% Arduino or Arduino Mega compatible and cheaper than the Arduino/XBee.
 Looking at the prices -- this means no module (after all, the atmel module is not much cheaper than the xbee).  Just an AVR, the RF230, voltage level converter CPLD, (and maybe option to have USB -- or use the USB FTDI cable).
What is extremely interesting about this to me is that the 328 base cost of materials is $8 if we made 50-100 or so.  This is just those chips; the addition of the Arduino-compatible female headers, voltage regulator chip etc would push the hardware cost to about $11-$12.
At that price point (say $10-$15) you really could think about buying 5 to 20 of them on an garage-tinkerer's budget, for wireless sensor fun!
And of course we could also do a 1280 (its a $10 chip) version both for inopia's work and also perhaps as the "base station" for all of these smaller nodes.
This would be a lot cooler than the current XBee stuff... when I've looked at the projects (and don't get me wrong, they are cool!) they are mostly controlling [one thing] through an iphone; probably because it takes $90 to buy 2 of them so people only buy 2 and hook 1 up to the computer as the "router" and have one sensor.
I'd like to truly enable Arduino users to do sensor networks cheaply...
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
@vxir: we can also go for the single chip solution: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=ATMEGA128RZAV-8AU-ND
Unit price for >25 units is $7.61, which gives you an ATMega1281 + AT86RF230 in a single chip. You could just drop that chip into the arduino mega schematics, add an antenna jack and there you are.
I also found this: http://www.dresden-elektronik.de/shop/prod28.html - it's the company that seems to produce atmel's zigbee demonstration kits. They have cheap nodes (although the programmer board is a tad expensive at 60 euros).
I must say that your price assessment seems _very_ low though, so I'm inclined to multiply it by two in my head :3
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
@vxir: you could also just drop an AT86RF230/1 onto a shield as it needs only SPI and two I/O lines :3
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Now that everyone sabotaged my post I shal try to gain it back again with a new shield :p
Arduino Multiplexer shield (48 analog inputs/digital inputs or outputs)
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1248736243/0
Mowcius
Logged
Indiana
Offline Offline
Newbie
Arduino rocks
View Profile
Quote
Thanks for the good word mowcius.
More info is also here:
http://mayhewlabs.com/arduino-mux-shield
Also, now that this project is finished, I am interested in designing and implementing more shields.  So if I can help in any way like PCB layout, manufacturing, or doing small production runs, let me know!
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I've been taking a look at GSM/GPSR modules for a shield. I have came across 2 different ones already developed for the arduino, one for like 70euros and the other for 99euros. That seems expensive to me. Would it be that hard to take apart an AT&T prepaid phone that you can get at Best Buy for $30 US and etch your own board.
I'm just fishing for thoughts on this.
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
I have thought that many a time but unfortunately they are not easy to implement and phone buyers buy thousands so they get them on the cheap so it is much more expensive to buy a few for an arduino shield.
If you gat anything sorted then I will be very happy to help you along and buy a few smiley-grin
Mowcius
Logged
Offline Offline
Full Member
Arduino rocks
View Profile
vxir,Inopia, et al,
there are Zigbit module breakout boards available now:
http://www.lextronic.fr/P4374-module-devaluation-zigbit.html
http://www.lextronic.fr/P4360-platine-devaluation-pour-module-zigbit.html
http://www.mikroe.com/en/tools/zigbee/easy-zigbee/
http://www.mikroe.com/en/tools/zigbee/zigbee-proto/
If we discuss this further, please start a new thread when 'replying', so we can discuss wireless comms there, and not impinge on the OP's thread. Thanks mowcius. smiley-wink
Logged
Pages: 1 ... 3 4 [5]   Go Up
Print
Jump to:
