Topic: Looking for thin/flat temperature sensors.. (Read 939 times) previous topic - next topic
I'm looking for a thermocouple or some sort of flat/thin temperature-sensing device. The important temperature range will be 60-150 deg F (15-65 deg C). Ideally, it would be the thickness of single-ply cardboard or less (not corrugated cardboard), perhaps 1/4 inch wide and 2-4 inches long.
Can I buy wire that is sensitive to temperature, or is there some off-the-shelf solution that would work well for this?
Check out Omega.  They have an incredible variety of thermocouples.
A standard bead type thermocouple would probably fit the bill.
Thanks much. Here's what I'll end up using:
Those are what I was thinking of when I read your description.  I think I saw some on ebay in the last couple of days.
