Topic: uno 328p & dataman pro+ (Read 526 times) previous topic - next topic
biocustomconsoles
Hello, at work we use dataman to program ic's. We got a lot of black 328p  in and I made a optiboot rig with a uno. Works great with the ide program after loading boot.
If I program a ic with the dataman then put back into uno, its works but I can no longer use ide program.
keeps giving the sync errors and the rx tx  blink not in sync.  If I reload optiboot on ic then works again.
What setting on dataman program do I need to set up to be able to use both programs? Thanks
CrossRoads
Once you put on Optiboot, then the chip is expecting sketches to be uploaded using the Serial port.  If you program via the SPI pins, that overwrites the boot area and there is no bootloader to look for sketches from the serial port.
So you need to create a file that has both optiboot and the program together.
This was discussed in the forum last week.
spycatcher2k
Sounds like you are not setting the lock fuse after bootloading them.
http://www.uk-pcb.co.uk - UK Based PCB Fab Company
I will code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
hugo007
I don't think so.
The CrossRoads answer  is more accurate
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
spycatcher2k
OK - Misunderstood the problem.
biocustomconsoles
Ok. I will look it up. I try search here on dataman but didn't find nothing about this.
