Topic: help with rgb day/night cycle using mills() (Read 860 times) previous topic - next topic
Mccluskey1181
so i have wired up an RGB strip correctly and it all works, i just need some help with the code.
bellow is the code, and in the //'s is the time i would like the fade/the over all time for that cycle to last. at the moment I'm getting a strobe effect. i did pinch the sketch from a tutorial online and tried to modify it. also, how do i get by the 50 day millis reset, or should the sketch be ok to carry on running after the 50 days?
thanks for any help!
int brightness = 0;
int fadeAmount = 5;
int rPin=9;
int gPin=10;
int bPin=11;
unsigned long currentTime;
unsigned long loopTime;
void setup()  {
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11,OUTPUT);
  currentTime = millis();
  loopTime = currentTime;
//DAWNORANGE fade for 30 minues
void loop()  {
  if(currentTime >= (loopTime + 20)){
    analogWrite(9, 161);
    analogWrite(10,158);
    analogWrite(11,156);
    brightness = brightness + fadeAmount;
    if (brightness == 0 || brightness == 255) {
      fadeAmount = -fadeAmount ;
//DAWNYELLOW fade for 30minutes
    // set the brightness of pin 9:
    analogWrite(9, 163);
    analogWrite(10,159);
    analogWrite(11,150);
{ //CARBONARC fade for 30 minutes
    analogWrite(9, 255);
    analogWrite(10,250);
    analogWrite(11,244);
{ //FULLSUN fade for 3.5 hours
    analogWrite(9, 250);
    analogWrite(11,250);
{ //HIGHNOON fade for 1 hour
    analogWrite(10,255);
    analogWrite(11,251);
{ //FULLSUN stay for 7 hours
    analogWrite(11,255);
{ //DUSKORANGE fade for 30minutes
    analogWrite(10,214);
    analogWrite(11,165);
//DUSK BLUE fade for 30 minutes
    analogWrite(9, 38);
    analogWrite(10,83);
    analogWrite(11,141);
{ //moonlightblue for 1 hour
    analogWrite(9, 0);
    analogWrite(10,85);
//MIDNIGHTBLUE 1hour
  {currentTime = millis();
//night 8hours
    analogWrite(9, 0);
    analogWrite(10,0);
    analogWrite(11,0);
robtillaart
using CTRL-T will reformat your code
together with code tags (#button above the smileys) it becomes more readable
Advice, millis will be too inaccurate for the long term, use an RTC (DS1307 or better DS3232 ?)
If you want to do it without RTC, you can build a 'circadian' clock.
1) Use an LDR to measure the moment of dawn and dusk
2) use millis() to time the time between these two.
3) The middle between dawn and dusk == 12:00 (noon)  (approx, you need to tune that).
4) The other middle is 0:00 (midnight)
Will work like a charm and will adapt itself automatically (in a day or so) in spring winter summer and even when shipped to another timezone!
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
