Topic: Breadboard Arduino Problems (Read 4866 times) previous topic - next topic
HighSeraphim
Apr 11, 2010, 11:36 pm Last Edit: Apr 11, 2010, 11:42 pm by HighSeraphim Reason: 1
I am trying to implement my arduino on a breadboard. I have tested my setup on the dev board that I used to program it and it worked.
Now I have used this as a guide:
http://cdn.shopify.com/s/files/1/0038/9582/files/RBBB_Instructions_06.pdf?1260749296
to put my atmega328 on a breadboard. I don't have any of the caps or the indication diodes. I'm wondering if the caps are critical? They don't seem like they should be.
I have power to the correct pins and my chip is behaving erratically.
I have a 16Mhz oscillator and I'm reading 4.98VDC to VCC and AVCC. I have my grounds connected on the chip.
Coding Badly
Do you have the two capacitors for the oscillator?
HighSeraphim
It is an ceramic package with internal caps. It's a three pin device.
AlphaZeta
If you are using ceramic resonator then you don't need the caps on pin 9 and 10.
HighSeraphim
Aye I am using a ceramic resonator and I'm not using any of the caps. :)
HighSeraphim
I should just plug the outer two pins of the resonator into pins 9 and 10. Then the middle pin goes to ground correct?
Coding Badly
Are you working with just the processor or do you have other electronics (LEDs, servos) involved?
HighSeraphim
I have some other electronics involved.
HOWEVER; I have tested them with the Duemilanove development board  and they worked fine.
Everything falls apart when I try to put the ATMega328 on the breadboard instead.
estranged
#8
Apr 12, 2010, 05:54 am Last Edit: Apr 12, 2010, 06:00 am by estranged Reason: 1
I've had very good results from following the breadboard writeup at the following site:
http://www.imagearts.ryerson.ca/sdaniels/physcomp/tutorials/Arduino_standalone/ard_hack.html
Its always good to start with the basic blinking LED sketch too, just to make sure the breadboard setup works before getting too ambitious with additional components.
MarkT
Quote
Decoupling capacitors are a must for any, repeat any digital circuitry.
MarkT
Oh and the voltage regulator may well need its decoupling capacitors to prevent oscillation.  You've probably made a low power radio transmitter ;)
HighSeraphim
This is of note and should be made into a sticky: the 328 has internal caps on the clock inputs.
It works with a a 16mhz crystal installed between the two pins. There is no need for caps and a ceramic oscillator doesn't work.
Grumpy_Mike
#12
Apr 14, 2010, 05:58 pm Last Edit: Apr 14, 2010, 05:59 pm by Grumpy_Mike Reason: 1
Quote
Why do you say this? the data sheet shows external capacitors (page 29)
and on the same page give start up data for ceramic resonators.
I use capacitors on 328 stand alone systems without problems.
Am I missing something?
retrolefty
#13
Apr 14, 2010, 09:51 pm Last Edit: Apr 14, 2010, 09:56 pm by retrolefty Reason: 1
Quote
While you may have got yours to work, we shouldn't let this statement stand for others to use in the future, let alone make it a sticky.
1. While the 328 AVR pins 9 & 10 each do exhibit some amount of capacitance to ground, it is not generally enough to let crystals work accurately at their specified frequency, and may cause fail to start up or sluggish starting. Even if a crystal will oscillate without using external padding caps, accuracy will suffer somewhat without the use of external padding caps such that the total capacitance (internal + external) are what the crystal was specified to work with.
2. Three pin ceramic resonators do work with the 328 processor, and yes they have internal padding capacitors wired from the outside pins to the middle pins, just be sure to ground the middle pin. I have at least two 328 processors using ceramic resonators and they work just fine, they just don't quite have the accuracy of a crystal resonator, but in most cases that is not an important issue.
Lefty
HighSeraphim
I have 4x 328s here.
I can't get ANY of them to work with a three pin resonator or a crystal with two caps.
They only work when I have the two pin crystal plugged in.
If other people have other results, I can't explain the phenomena
