Topic: Breadboard Arduino Problems (Read 4862 times) previous topic - next topic
retrolefty
#15
Apr 15, 2010, 12:12 am Last Edit: Apr 15, 2010, 12:13 am by retrolefty Reason: 1
I have 4x 328s here.
I can't get ANY of them to work with a three pin resonator or a crystal with two caps.
They only work when I have the two pin crystal plugged in.
If other people have other results, I can't explain the phenomena
It's possible the fuse settings for your 328  chips are set such as not to be proper for the standard oscillator settings. Check out an AVR datasheet for the fuse options offered for oscillator function and if you have the means to read your fuse settings, see if it is set up correctly.
The standard fuse setting for an Aduino 328 are:
low_fuses=0xFF
high_fuses=0xDA
extended_fuses=0x05
Lefty
Senso
If you are mounting then in a breadboard, the board itself may have enought capacitance to let the cristal work properly, but when you add the caps it as too much and can't work, using high clock signals in a breadboard is always asking for troubles.
HighSeraphim
I moved the chip to a PCB and had the same effect.
I mean... It's not a problem for me because it's working just fine. I just wish I new why. :)
estranged
I have tested my setup on the dev board that I used to program it and it worked.
What dev board did you use to program it?
Are the 4 328's you tried from a regular Arduino board, or did you just buy them as parts?  Maybe the chips don't have the Arduino bootloader / fuses set and instead is operating off the internal 1MHz oscillator?
HighSeraphim
No i used the standard arduino dev board to program them. IF they were programmed to run off of the internal clock, adding an external ceramic oscillator wouldn't make them malfunction anyways right?
It really seems to be an odd situation as right now I feel like my reality is not congruent with everyone else's...
