Topic: Audio project help, please (Read 632 times) previous topic - next topic
fladeisn
Hello.
This project I have is to let arduino play human voice with the PWM sample we found on the playground, with the difference that this one is getting the data from a serial connection.
The problem is that if the arduino gets the data from a USB connection, the audio quality is fine, but If it gets the data wirelessly from an xBee, then the sound is really really poor (almost pure noise).
Please help me, I have tried everything, and a I'm a newbie on this.
Code: [Select]
int a = 0;
int ledPin = 13;
int speakerPin = 11;
char inData[3];
char numero[3]; // Allocate some space for the string
char inChar; // Where to store the character read
byte index = 0; // Index into array; where to store the character
long arraySize = 999999;
byte num;
* speaker_pcm
* Plays 8-bit PCM audio on pin 11 using pulse-width modulation (PWM).
* For Arduino with Atmega168 at 16 MHz.
* Uses two timers. The first changes the sample value 8000 times a second.
* The second holds pin 11 high for 0-255 ticks out of a 256-tick cycle,
* depending on sample value. The second timer repeats 62500 times per second
* (16000000 / 256), much faster than the playback rate (8000 Hz), so
* it almost sounds halfway decent, just really quiet on a PC speaker.
* Takes over Timer 1 (16-bit) for the 8000 Hz timer. This breaks PWM
* (analogWrite()) for Arduino pins 9 and 10. Takes Timer 2 (8-bit)
* for the pulse width modulation, breaking PWM for pins 11 & 3.
* References:
*     http://www.uchobby.com/index.php/2007/11/11/arduino-sound-part-1/
*     http://www.atmel.com/dyn/resources/prod_documents/doc2542.pdf
*     http://www.evilmadscientist.com/article.php/avrdac
*     http://gonium.net/md/2006/12/27/i-will-think-before-i-code/
*     http://fly.cc.fer.hr/GDM/articles/sndmus/speaker2.html
*     http://www.gamedev.net/reference/articles/article442.asp
* Michael Smith <michael@hurts.ca>
#include <stdint.h>
#include <avr/interrupt.h>
#include <avr/io.h>
#include <avr/pgmspace.h>
#define SAMPLE_RATE 8000  //8KHz sample rate
* The audio data needs to be unsigned, 8-bit, 8000 Hz, and small enough
* to fit in flash. 10000-13000 samples is about the limit.
* sounddata.h should look like this:
*     const int sounddata_length=10000;
*     const unsigned char sounddata_data[] PROGMEM = { ..... };
* You can use wav2c from GBA CSS:
*     http://thieumsweb.free.fr/english/gbacss.html
* Then add "PROGMEM" in the right place. I hacked it up to dump the samples
* as unsigned rather than signed, but it shouldn't matter.
* http://musicthing.blogspot.com/2005/05/tiny-music-makers-pt-4-mac-startup.html
* mplayer -ao pcm macstartup.mp3
* sox audiodump.wav -v 1.32 -c 1 -r 8000 -u -1 macstartup-8000.wav
* sox macstartup-8000.wav macstartup-cut.wav trim 0 10000s
* wav2c macstartup-cut.wav sounddata.h sounddata
//#include "sounddata.h"
#define SAMPLEINDEX_MASK 0x0FFF
//Used to implement phase increment resampling
uint16_t sampleStep;  //The step size for each sample. All 16 bits are used.
                     //The lower 12 are fractional steps. A step size of 0x01000 is equal to one step
                     //per sample. Also, this means that playback can be done at a maximum of 16X the
                     //orignal rate.
volatile unsigned long sampleIndex; //Keeps the current sample index.
//Used by the ISR and initalizaiton methods
uint16_t samplePoint;
unsigned int sampleValue;
//Prototype for DAC output function
//The idea is to abstract the type of DAC used. It is assumed that the DAC would never have more then
//16 bits of resolution so an unsigned int is used. If you intened to have 8-Bits of resolution then you
//need to upshift the input (value<<8). This does add some time/hassel but it support the concept of
//differnet resolutions independent of the applicaiton code.
//The second parameter is the DAC channel. For the inital test code one is used for the PWM DAC and
//and the other is for the R2R DAC. In a future version I want to have Left and Right channels
#define DAC_PWM 1
#define DAC_R2R 2
void SetDAC(unsigned int outputValue, unsigned int channel);
//Lower level funcitons to actualy set the specific DAC type. Used only by the SetDAC funciton.
void SetDAC_PWM(unsigned int outputValue);
void SetDAC_R2R(unsigned int outputValue);
ISR(TIMER1_COMPA_vect) {
void startPlayback() {
   pinMode(speakerPin, OUTPUT);
   sampleStep=0x2000; //Set to orignal sample rate.
   // Set up Timer 2 to do pulse width modulation on the speaker
   // pin.
   // Use internal clock (datasheet p.160)
   ASSR &= ~(_BV(EXCLK) | _BV(AS2));
   // Set fast PWM mode  (p.157)
   TCCR2A |= _BV(WGM21) | _BV(WGM20);
   TCCR2B &= ~_BV(WGM22);
   // Do non-inverting PWM on pin OC2A (p.155)
   // On the Arduino this is pin 11.
   TCCR2A = (TCCR2A | _BV(COM2A1)) & ~_BV(COM2A0);
   TCCR2A &= ~(_BV(COM2B1) | _BV(COM2B0));
   // No prescaler (p.158)
   TCCR2B = (TCCR2B & ~(_BV(CS12) | _BV(CS11))) | _BV(CS10);
   // Set initial pulse width to the first sample.
   //sampleValue=pgm_read_byte(&sounddata_data[0])<<8;
   //sampleValue = num;
//    SetPWMDAC(sampleValue);
//    SetR2RDAC(sampleValue);
   // Set up Timer 1 to send a sample every interrupt.
//   cli();
   // Set CTC mode (Clear Timer on Compare Match) (p.133)
   // Have to set OCR1A *after*, otherwise it gets reset to 0!
   TCCR1B = (TCCR1B & ~_BV(WGM13)) | _BV(WGM12);
   TCCR1A = TCCR1A & ~(_BV(WGM11) | _BV(WGM10));
   // No prescaler (p.134)
   TCCR1B = (TCCR1B & ~(_BV(CS12) | _BV(CS11))) | _BV(CS10);
   // Set the compare register (OCR1A).
   // OCR1A is a 16-bit register, so we have to do this with
   // interrupts disabled to be safe.
   OCR1A = F_CPU / SAMPLE_RATE;    // 16e6 / 8000 = 2000
   // Enable interrupt when TCNT1 == OCR1A (p.136)
   TIMSK1 |= _BV(OCIE1A);
//    lastSample = pgm_read_byte(&sounddata_data[sounddata_length-1]);
   //sampleIndex = 0;
//    sei();
void SetDAC(unsigned int outputValue, unsigned int channel) {
 switch(channel) {
   case DAC_PWM :
     SetDAC_PWM(outputValue);
   case DAC_R2R :
     SetDAC_R2R(outputValue);
//Set the PWM D/A converter output
void SetDAC_PWM(unsigned int outputValue){
 //This implementation uses PWM in 8 bit mode.
 //Load the upper 8 bits into the PWM control register
 OCR2A = (outputValue>>8)&0xFF;
//Set the R2R D/A converter output.
void SetDAC_R2R(unsigned int outputValue){
 //We are using port D bits 2-7 for a 6-bit D/A.
 //Bits 0 and 1 are serial which we dont want to disturb
 PORTD=(PIND&0x03)|((outputValue>>8)&0xFC);
#define MAX_STEP 0x05000
#define MIN_STEP 0x00400
 //Set the LED pin mode to output.
 pinMode(ledPin, OUTPUT);
 //Iniciar el serial a 115200 bps
 Serial.begin(142500);
 //2 bits de paro / 2 stop bits
// UCSR0C = UCSR0C | B00001000;
// UCSR0C |= (1 << USBS0); // right after calling Serial.begin ();
 //Setup the hardware for the D/A converter
// DDRD|=B11111110; //Set upper 6 as ouput, lower are TX and RX
 //Set an inital phase step size.
 sampleStep=MIN_STEP;
 //Setup the timers for the ISR and PCM generation
 startPlayback();
 //Parpadear LED para indicar que funciona correctamente
 for (int i = 0; i<3; i++){
   digitalWrite(ledPin,HIGH);
   delay(250);
   digitalWrite(ledPin,LOW);
   delay(250);
 //To demonstrate the phase steping feature set the phase step as a function
 //of the A/D input on input 0. Hook up a pot to vary the phase step and resample the
 //sound at diffenret frequencies.
 //for(int i = 0; i<255;i++)
   //sampleStep=MIN_STEP+(analogRead(0)<<3);
   //sampleStep=MIN_STEP+i;
while(Serial.available() > 0) // Don't read unless you know there is data
      if(index < arraySize) // One less than the size of the array
           inChar = Serial.read(); // Read a character
           //Que reciba caracteres hasta que llegue una coma
             if (inChar!=','){
                   inData[index] = inChar; // Store it
               index++; // Increment where to write next
               inData[index] = '\0'; // Null terminate the string
             //Si el caracter es coma, que lo mande a numero
             if(inChar==','){
               for(int i = 0; i<3;i++){
                 numero[i]='\0';//Borrar cada caracter de numero para poder escribir en el de nuevo
                 if(inData[i]!='\0')
                   numero[i] = inData[i];
               //Ahora en entero
               char * thisChar = numero;
               a = atoi(thisChar);
               num = a;
               index = 0;
       //delay(10);
       OCR2A = num;//QUe lo saque por el pwm
   //SetDAC(a, DAC_PWM);
fladeisn
I have found the problem.
As you said, it was interference. If I shut off all the cellphones around and disconnect the WiFi, there's no distortion on the sound.
How can I change the XBEE channel or frequency?
Thanks :) :-[
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
