Topic: GSM - GET HTTP request via a php file (Read 6480 times) previous topic - next topic
GabrielSoare
Hi Arduino!
I'm trying to send data from my arduino mega which has attached a GPRS module.
Connection and setup for GPRS module it was a success, also the backend part but i have some trouble with connect to my php file.
Take a look on my short code. maybe you can figure what's my problem easily.
Code: [Select]
// include the GSM library
#include <GSM.h>
// PIN number if necessary
#define PINNUMBER ""
// APN information obrained from your network provider
#define GPRS_APN       "web.vodafone.de" // replace with your GPRS APN
#define GPRS_LOGIN     ""    // replace with your GPRS login
#define GPRS_PASSWORD  "" // replace with your GPRS password
// initialize the library instances
GSMClient client;
GPRS gprs;
GSM gsmAccess;
// This example downloads the URL "http://arduino.cc/latest.txt"
char server[] = "agroaktiv.de";//"agroaktiv.de"; // the base URL
char path[] = "/wetterstation/status.php?device=fromtheroof&temp1=30&temp2=12&rainfall=0"; // the path
int port = 80; // the port, 80 for HTTP
  // initialize serial communications
  Serial.println("Starting Arduino web client.");
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // pass the PIN of your SIM as a parameter of gsmAccess.begin()
  while(notConnected)
    if((gsmAccess.begin(PINNUMBER)==GSM_READY) &
        (gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD)==GPRS_READY))
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("connecting...");
  // if you get a connection, report back via serial:
  if (client.connect(server, port))
    Serial.println("connected");
    // Make a HTTP request:
    client.print("GET ");
    Serial.print("GET ");
    client.print(path);
    Serial.print(path);
    client.println(" HTTP/1.0");
    Serial.println(" HTTP/1.0");
    client.println();
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available())
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.available() && !client.connected())
    Serial.println("disconnecting.");
    client.stop();
    // do nothing forevermore:
    for(;;)
This is what I get
Code: [Select]
connecting...
connected
GET /wetterstation/status.php?device=fromtheroof&temp1=30&temp2=12&rainfall=0 HTTP/1.0
HTTP/1.1 404 Not Found
Content-Length: 191
Server: nginx
Date: Fri, 09 May 2014 10:21:01 GMT
Content-Type: text/html
Last-Modified: Mon, 09 Dec 2013 10:57:51 GMT
ETag: "82cda-3bf-4ed17de070608"
Accept-Ranges: bytes
X-Powered-By: PleskLin
MS-Author-Via: DAV
Connection: close
<HTML><HEAD><TITLE>404 Not Found</TITLE> </HEAD><BODY><H1>Not Found</H1>The requested document was not found on this server.<P><HR><ADDRESS>Web Server at v681.ncsrv.de</ADDRESS></BODY></HTML>
disconnecting.
I don't know what to say more.
Cheers,
Gabriel
zumiki
This is how it should be.
Be sure to test status.php using a form.php to post it.
client.print("GET http://agroaktiv.de/wetterstation/status.php?device=fromtheroof&temp1=30&temp2=12&rainfall=0");
client.println(" HTTP/1.1\r\n");
client.println("Host: agroaktiv.de");
Good luck!
ArmGsm
Hi
i have problem
i have Arduino UNO And Arduino GSM shield
i have Sim card
i wanto to turn on/off led via internet
i dont know how can i configure GSM, that connect internet via sim card
i dont know what i need to write on PHP fail
can you send me example with GSM configuration , HTML fail and PHP?
thank you very much
RudiAhlers
Hi Arduino!
Code: [Select]
#include <GSM.h>
GSMClient client;
GPRS gprs;
GSM gsmAccess;
  // connection state
  // Start GSM shield
  while(notConnected)
    client.print(path);
    Serial.print(path);
    client.println();
    Serial.print(c);
    client.stop();
    for(;;)
This is what I get
Code: [Select]
connecting...
connected
Content-Length: 191
Server: nginx
MS-Author-Via: DAV
Connection: close
disconnecting.
Cheers,
Gabriel
The 404 error means your ASP script isn't where you think it is. Double check the URL in a web browser and correct your code accordingly. caPAtaLiZatiON matters
